First impressions:
Shipped from: Gearbest for review purpose
348 link: http://goo.gl/I7VFVn
Coupon: GBBLF348 Price: $7.99
BLF EDITION 348 link: http://goo.gl/1907X5
Coupon: GBBLF348 Price: $6.99
The range of new single AAA flashlights is always growing and the market is always trying to offer the best possible components, and this is the exact case of the SingFire SF-348 built in special edition with the Nichia led NVSW219BT-V1 that’s rated for CRI: Minimum 90.
I personally like its simple and sleek design, maybe the only one downside is the fact to have only 1 mode(on/off), so you can’t adjust the runtime as you want.
Modes and estimated lumens:
Switch type: MECHANICAL
There is only 1 mode: HIGH (so runtume can’t be the best)
My estimated lumens are 80 on NiMH and 200 on 10440 IMR
>>LIGHT >>> The angle of refraction:
Weight and dimensions measurements (made myself, not by specs):
This flashlight weighs precisely 27,4 gr
Height 9 cm
Diameter 1,2 cm
Head diameter 1,2 cm
Construction quality:
The stainless steel body is perfect on my unit and i can say you that there’s virtually a 0 conjunction gap between the central body and the screwable front bezel art and the rear tailcap, it seems like an UNIQUE piece of stainless stell cilinder
In my hopinion this is one of the best host i’ve seen, for a single AAA flashlight, ok maybe it’s too much “minimal” for some people but whilst i love futuristic desighs on 18650 and multiple 18650 flashlights, i still continue to prefer simplistic design for 1xAAA to, associated with high quality materials.
For example my Olight i3s with its aluminum host is heavily ruined on external appearance (color goes away aftertime…)
Disassebling the internal components i see that they’re very well built but i’m a little disapponted which they didn’t add at least one more mode, an extreme low for example to just have 3 or 7 lumens and save battery.
The one click mode, is at least simply and effective and could be a pro for someone.
The beam is quite good for low to medium low distances, it does have a big and blunted hotspot which naturally fades into spill without a concise circle
Lanyard hole: NOT PRESENT
Threads came NOT GREASED, but this is not a big con, i used my grease.(mine isn’t an high quality one, but you can buy a top notch if you prefer)
Led Tint, reflector and lense:
The led is not perfectly centered and its tint is pure neutral white (4745 - 5310K)
Reflector made of: ORANGE PEEL – ALUMINUM
Lense made of: GLASS , without AR coating
Outside beamshot at 25 meters, only at FULL power (same place for all my reviews)
(1GIF)
Wall beamshot at 250 centimeters, from lower to higher power (same place for all my reviews)
Ceiling bounce test with LUXmeter:
PROS:
- NVSW219BT-V1 allows you to see the REAL COLORS around you
- host style appearance
- quality materials
- usable with lithoum 10440 but temperature will raise…a lot!
CONS:
- beam not optimized for long distances (and warm tint does not help to see at high distances)
- only 1 mode
Final thoughts and why you should buy it:
This is a flashlight for whose who want a durable and hard to scratch item, capable to help you in low distances with the great comfort to have a naturally color vision of objects around you.
I think that the price is really good for this kind of led with high CRI 90 and this could be your preferite EDC flashlight to carry everywhere… with the only one limit to use it at low/medium distances and not for a long time, because if you’re needing a long runtime AAA flashlight this one can’t be the best one with its 1 mode, but it’s also true that if you buy a flashlight that uses this type of battery your intention should not be… to see for “a long time” and at “long distances”….for this needings you have to buy a 18650 flashlight.
Thanks for reading……
….and if you notice some bad written phrases, feel free to correct me suggesting the right way to write it!!
