The good Kings had tailcap currents in the 6A range. Anything in that ballpark is good, but 8A would be per-emitter equivalent.
I just hope for a good build light, the driver doesn’t matter too much to me; one of those DD drivers that has been pictured is fine because I’ll probably mod it for 3A/emitter regulated.
The difference between T6 and U2 emitters is about 8% higher output with U2, given the same current. On average. That code is the flux bin rating. Cree tests every emitter and gives them a bin rating based on their luminous flux. The flux bin they fall into is what they end up being sold as (similarly, computer CPUs are binned based on their maximum stable operating frequency).
Physically, the emitters look identical. Visually, it is virtually impossible for the human eye to differentiate a 7% change in output. You would need to measure it.
U2 is about 7% brighter than a T6 and that’s mainly it.
There is also the tint issue which is basically a lottery, when U2’s where new they where more likely to be cooler than T6’s but i doubt this is the case anymore.
Given the simplicity of the drivers that apparently have, vs. the original SRK (with toroids/inductors, etc.), it seems less likely that any revisions might be inferior quality?
I mean, I guess that they might eliminate the FETs, and go to a “pure” true direct drive, to save some costs, but (a) the resulting light would probably be brighter and (b) the costs of current limiting power-rated resistors might be almost the same as the FETs?
This is very good info to know about, at least for me, thanks!
That was going to be my other question, tints. I like my lights cool/cold white (6k-7k) Do either of these T6 or U2 come close that tint or color temperature?
I’m still wondering, if the manufacturer were going to try to reduce their costs on this particular light, I’m wondering where would they be able to do that, that would significantly reduce performance? At least from the pics on this thread, it seems like a pretty barebones driver, so maybe somewhere else, like the emitters, or the switch, or…? FYI, I’m not arguing, but just wondering….
