[CCed from Amazon, pix to follow]
SP31v2… a great yet simple light
I gotta confess, I didn’t think I’d be too wowed by this light, but I was wrong. I have lots of dual-switch lights, so how would this new SP31 set itself apart? I had to find out…
Simplicity, for one thing. The UI (user-interface) is about as simple as you can get.
First things first. This was the kit, not the light-only, so it included the usual 3000mAH Sofirn cell, as well as usb cable and charger. And as usual, the cells clock in at almost exactly 3000mAH. The charger is simple enough: toss in a cell, power it up, and it’s red while charging, green when it’s done.
The light comes in the new style orange and black Sofirn box, with plastic tray cradling the light and providing storage for the charger, usb cable, lanyard, and manual. The cell is inside the light but insulated with a small disc which needs to be removed first.
First impressions are good as usual. The ano is a flawless semigloss black, no voids anywhere. No sharp edges or corners anywhere on the light. There’s a chromed clip which is incredibly sturdy and holds quite well, but to me still looks like an afterthought, as it’s common to quite many lights. I dislike clips anyway, so I’m biased. :smiling_imp:
The UI is simple. It’s a dual-switch light. The tailswitch is simply for on and off, and is a forward-clicky, so it allows momentary on! The sideswitch is only for changing modes. Simply click to advance to the next mode. There’s no doubleclicking or anything. A doubleclick just advances twice. The only exception is a press’n’hold, which gets you to the annoying blinkies (strobe, then SOS, then strobe again, etc., with each click). Another press’n’hold gets you to your last normal light setting, or just turn it off then back on again.
My only would-be improvement would be to ditch the blinkies entirely, and use press’n’hold as a shortcut to either the lowest or highest setting.
But there’s no way to screw up anything. On/off is simple enough, click to advance is also simple. This would be a great light for The Muggle. The only improvement there would be onboard charging, so The Muggle wouldn’t have to remove the cell to charge it. But the UI makes perfect sense to even a “beginner” using a high-performance light. No doubleclicking, or click-click-hold, none of that to get anyone in trouble, or get stuck in some Mystery Mode. Nice!
A nice benefit of the lit sideswitch is to tell how much power-juice is in it. For about 5sec after turning it on, it lights either red or green. Green means plenty of power. Red means you’re running low. I haven’t yet run a cell so low to see its low-voltage warning (blinking at 3.3V) or low-voltage protection (turning off at 3.0V).
There are 5 levels, from lowest (“eco”) to highest, and again, clicking just cycles through them. They’re nice and evenly spaced, no huge jumps from one level to the next. According to the manual (and I have no reason to disbelieve it), the levels are 5lm, 50lm, 160lm, 500lm, and 1200lm. Sounds about right.
It’s also thermally regulated, so the light will cut back on power if it’s left on too bright for too long. Nifty!
One of the best features of the light is the LH351D in it. Light output is a nice creamy white and has great color rendition as well. I’ve gotten spoiled.
Compared to other lights that don’t have a ’351 emitter, this one just shines.
And the beam is nice and doesn’t have any artifacts. Very nice.
Also, in a pinch, you can also use a pair of CR123A cells, as the driver supports a higher voltage than just one lithium cell. This comes in really handy if you’re out in the sticks and don’t have a charger (or the electricity to charge anything), but have some ’123s in case of emergency. Being that they have a shelf life of at least 10yrs (more like 20), they make good backup cells for those lights that can use them.
I’ve been using it quite a while now, and it makes a great around-the-house light as well as an EDC (everyday carry).
All in all, I’m liking this SP31v2 more and more each day. I love forward-clicky switches and momentary-on, which usually only happens with dual-switch lights. The simplicity of the UI (I usually keep mine on the lowest but “crank it up” if I need more light) makes it a simple task to be able to switch it on/off even momentarily for a quick flash of light. So especially at home, it makes a great nighttable light, etc.
Impressive, and I’m impressed. I probably have to get another one just to not be without.
