Pictured is the old or original L2M with the new 2012 version …
And there have been improvements made , fit and finish has has been improved , in fact the fits are now very much comparable with the Surefire , machining is really clean and precise .
There have been changes : The battery tube is now shorter [ original was a little long ]
The rubber tail cap is larger , and the clicky switch can handle more current , and is now forward clicky
And some very slight external changes :
The changes made , are minor , but simply taking what was a very nice host , Solarforce has matched the standard by which all P60 hosts are measured by , the Surefire 6P .
In 2012 Solarforce has come of age , the 2012 Host line up is simply the best so far offered , and anyone looking for a P60 host would be seriously remiss to not look at the Solarforce line up .
The L2M is two flashlights in one [ or more if you wish ] , It can run on a 18650 or 16340 [ 18350 ] , and if you ran a low voltage drop in , with the 18650 extension in place of the CR123 extension [ or two CR123 extensions ] you could run 2xAA [ which I do with one of my L2m’s ]
I cant recommend the 2012 line up enough , the quality has improved , the finish has improved , I like the dull finish , I like the improved fits , the improved machining .
There is very little if anything left wanting …
I really like the 2012 L2M , it quite imply is a superb host for the money !
Mine is fitted with a very old drop in [ bout 3 year old tech ] for now [ Luxeon ] , single mode and pulls about 0.55A on a 18650 , the drop in is not important , but I like the combination …
Single mode low current drop in with a very slick host and forward clicky … Forward clicky does seem to work well with a single mode drop in , how about that …
Im now tempted , to build a single mode XM-L low current drop in for this host … But I digress …
Solarforce 2012 line up = They Rock , fantastic value for money , and ………………. just buy one !
