High mode efficiency from 84% to 90% depending on the input voltage.
Medium mode efficiency 94-95%
Memory function
Low voltage protection
Reverse polarity protection
First PCB Diameter: 15mm
Second PCB Diameter: 16.6mm
Total height: 6.5mm
Gold plated contacts
Tinned copper leads
Low voltage protection system:
*If the battery voltage is lower than 3V:
when the light is on (constant light), the output will be changed to 10mA.
when the light is flashing , the output will be changed to 50mA and keep flashing.
*If the battery voltage is lower than 2.7V, the output will be cut off but still there will be an input of about 0.3mA
(There will be no current consumption switching the flashlight off )
Measurements
Tested with: Cree XP-G2
Max. height: 6.5mm
Diameter: 16.5 mm and 15mm.
Strobe: 10Hz at 3.7 volt.
The driver has high, medium, low, strobe and sos.
The driver has memory, the actual mode is stored when the light is off for a short time.
A very short off/on will select next mode.
The driver is mainly buck, but can boost a little bit.
High
The drop in led current between 3.25 volt and 3.50 volt is probably the change from buck to boost.
Very good regulation, without any noise.
Medium
Due to inherited looses in the circuit, the boost need to be activate while the input voltage is above the Vf of the led.
Low
At low the boost is not needed and due to the low current there is some noise in the measurements.
Strobe
SOS
The spacing in the morse code is not correct.
Conclusion
This driver will provide full output from 3.0 volt to 5.5 volt with good efficiency.
I like this driver.
This is a very nice driver indeed. Because it works up to 5.5V, it would be nice to use it in a 4xAA NiMh configuration, the light will have a moderate but efficient output with good runtime and because of the good regulation it has a very good AA-alkaline compatibility.
Well…… looking at the 5.5v spot, it pulls .5 amps. Looking at his review of panasonic primary 123, it has a voltage of 2.75 at that current. Looks like it would work.
Just as a follow up, it looks like a TI TPS63000 driver chip for this driver. The data sheet. The max output is 800ma for the LED in the Boost mode. You can see from HKJs Hi mode chart, how the internal fet switches start doing double duty in the boost mode.
I’ve been using this little driver for a while in a small Crelant clicky. It’s been wonderful, and I’ve had no problems. It drives a Nichia 219 with one 14500.
