There is some updated info and pictures in posts 7 & 8. I will hopefully be doing more measurements and have more info to report in a day or two. I will update this OP for the new information as soon as possible.
This light is the next version in the Archer 1A line (succeeding the Archer 1A V2). It's a beauty with excellent mode spacing and lots of power. The light is turned On and Off by the tailcap. The side switch controls modes (Firefly, Low, Medium, High). Strobe is accessed from any mode with a long click. The driver has last mode memory that can be used for any of the 4 levels, but not for Strobe. I really like the UI on this light. After disassembling this light, I have to report that this light really does not need any mods. Its truly one of the best built light I have ever put my hands on.
The light has serious output on both Ni-MH and Li-ion. Product page says 200 lumens and that seems reasonable to me. I would guess high on Li-ion will be around 500 to 600 lumens. I, however, don't feel that I'm a good judge of lumen output. I have started to using a light box, but don't have a conversion factor established. When outside, I am surprised every time I put this light into high mode. The light box readings I got in my one brief output test were as follows:
Mode Ni-Mh 14500
Firefly 0 0
Low 36 36
Medium 146 162
High * 415 1130
* The numbers for High mode are approximate starting numbers. They steadily decrease over time. The numbers fluctuated a bit with Ni-Mh (Eneloop 3rd Gen), but were quite steady with a 14500 (Except High as it steadily decreases over time).
The light has awesome deep texture that kind of grabs you back. The tailcap helps protect its switch from unintentional activation, but has openings that make it easy to operating the tailcap switch. The light will tail stand, but is a bit wobbly if disturbed. The Pocket clip is strong and holds well.
I should disclose that this light was provided to me by ThruNite to review. I have done my best to not allow this review to be biased due to ThruNite providing the light to me at no charge. ThruNite has not tried to influence this review. Here are links to the their sited if anyone should like to contact them:
Official Website: http://www.thrunite.com (link is external)
Amazon US: https://www.amazon.com/dp/B01FCTD9PG/ (link is external)
Pros:
- Nicely spaced modes
- High kicks out bright smooth, floody beam.
- Hansom light
- Great texture, grippy
- Very nice Finish (Type III anodized)
- Beautiful OP reflector that renders smooth beam pattern
- Excellent thermal path for the emitter as follows:
- Copper Direct Thermal Path ("DTP") base under the emitter
- Integrated emitter shelf is well machined and flat
- The emitter base has an appropriate amount of thermal paste under it
- The emitter base is firmly screwed down onto a integrated shelf
- All threads are square cut and the battery tube is thick walled
- The driver looks sophisticated and has what appear to be high-quality components
- Ultra clear tempered glass lens with anti-reflective coating
- Side clicky (Momentary Switch)
- Can take Ni-MH and Li-ion
- Nice Clip
- Power switch in tail is protected to help reduce chance of accidental turn on
- Tail stands
- Spare Tail cap boot, O-rings, side-switch boot
- Well packaged with sturdy, good-looking box
- Threads/o-rings well lubed
- Strong, reversible and removable pocket clip
- Battery tube does not scratch when removing, installing, or rotating pocket clip
- Reversed polarity protection
- Strike bezel for emergency applications that isn't aggressive looking
Cons:
- Head and Battery Tube are glued.
- Tail stand can be disrupted by bumps, etc.
- Finish on the clip chips easily
- Bar code label should be slapped onto the bottom of the box for better gift presentation
Specifications (From ThruNite's website):
- LED: CREE XP-L V6 LED with a lifespan of 20+ years of run time.
- Modes & Run-time:
-Firefly: 0.1lumen(17days);
-Low: 17lumen(22hours);
-Medium: 75lumen(5hours)
-High: 200lumen(115minutes);
-Strobe: 200lumen(3.5hours). - Max output: 200lumens using one Ni-Mh AA battery.
- Max run time: 17days (Firefly mode)
- Working voltage: 0.9v to 5.0v.
- Battery: 1 AA
- Max beam distance: 66 meters.
- Peak beam intensity: 1088cd.
- Impact resistant: 1.5 meters.
- Waterproof to IPX-8 Standard (1.5meters)
- Weight: 42g without battery
- Dimensions: 110mm in length, 23mm bezel diameter.
- Accessories: Pocket clip x1, Spare O-ring x1, Lanyard x1.
Operation (From ThruNite's website):
- To turn on/off the light:
Press the tail cap halfway to momentarily ACTIVATE the light. Click the tail switch to turn the light on and off. - To change modes:
Five modes in total: firefly, low, medium, high, and strobe.
When the light is on, single press the side switch to rotate among firefly, low, medium and high.
Long press to get strobe and then single press to end it.
Memory function: The light will turn on in the last mode accessed, except for strobe. - Battery replacement:
Take off the tail cap, insert the battery with positive polarity toward the LED assembly(head of the light)
INSTALL the tail cap and tighten all the way to operate the light.
The package arrived 3 days after ordered via Amazon fulfillment in a letter sized bubble wrap envelop. Inside was a very sturdy and attractive box had a bar code sticker not been slapped on the top of it. Would be nice if they put it on the bottom for gifting purposes.
Contents included a manual in 6 different languages and ____ card (also in 6 different languages), a lanyard, spare tailcap cover, spare o-rings, and what appears to be a side-switch boot. The contents was nicely packed and didn't rattle.
Clip had a few chips. One on the end of each arm (Only one side shown as they both look the same) and very small chips on both sided of the top portion of the clip (Only one side shown again).
Really gorgeous reflector and super clear A/R lens. Here are a couple shots.
A few objects to give a size perspective.
Tail cap and switch assembly is nicely constructed:
Side-switch is protected with a rubber boot. Should be water proof to some extent.
Some bad news as to far further internal shots and as far as throw and efficiency measurements. I attempted to disassemble the head as I was very curious about the heat sinking and also wanted to measure voltage and current going into and out of the driver at Ni-Mh voltage levels and Li-ion voltage levels. Since the head was glued shut, I used a heat gun to soften the glue. I couldn't get the threads to budge one bit. I believe I kept the heat level reasonable, but apparently, something must have melted in the head and the light no longer works. I've opened up many glued lights before and never had a light quit working on me. Unfortunately, I also will not be able to get better beam shots. I will work on getting some comparison shots using a S15R Baton, Jetbeam-1-MK, and Odepro ED30. I did compare the Jetbeam side by side and the Archer 1A V3 is markedly brighter and floodier.
Here are the preliminary beam shots I got. Medium and High on Ni-MH (I need to measure the distance to the palm tree (Guessing at least 30ft). Firefly and Low are too dark to bother posting.
High on an aged Li-ion. Sorry, I didn't get medium shot. Medium on Li-ion and Ni-MH are that same.
Conclusion:
This is a sweet light. Truly, the best built light I have ever put my hands on. It needs no mods in my book. Well, maybe a lighted tailcap if one is going to use Li-ion cells.
