Yes it has low voltage warning, read the review
It cuts off on mine at 2.7V lowest to 2.9V. Usually around 2.8-2.85V.
Last time I ran the battery down it and took it out it had 2.9xV and raising.
No need for protected batteries with this light, I’ve had the monster Samsung INR 20A in it and nothing blew up in smoke.
I’ll take an xp-g2 over xm-l/l2 for throw any day of the week, xm-l is good for flood but an xp-g2 @ 2a in a 40mm reflector easily out throws an xm-l at 3+a in a 50mm reflector.
both provide usefull spill for walking about but the throw goes to the smaller, brighter die.
actually I did read it, as soon as you published it, but then you added new content on several occasions and I was like: "should I read it all over again from top to bottom? noooo, I'll just skip straight to "Confirm order"" :D
P.S. JackCY, will you order this one to and write a review :P I would like that ;)
I guess you could recommend it to Crystal and then somebody could get it for a review.
Is that a 7G5CS or 7G6CS clone, the bigger brother of 7G3CS?
If I do another review I’ll try to make it more to the point and make my own template as I got quite dissatisfied with this one.
Hopefully to cover all the parts of the flashlight without having to blah blah for so long and not knowing where to exactly put it.
Pictures or it didn’t happen
Really, why is there so few comparisons on BLF?
So many people have these emitters at home, just take a few pictures and post em on BLF people!
That's a clone of the V6CS. Doesn't really make sense to get it though - the original is cheaper: http://www.md-lightsource.com/Crelant-V6CS-XML-U2-710-Lumen-Throw-light-V6CS.htm
Also this clone says it has five modes... a major minus if they dropped ramping.
I just got the 7G6CS yesterday, and I'm loving it. It's not quite a pocket light though.
Got my C20 today, 17 days from Lights Castle, pretty quick for China Post. XTAR 18700 fits fine.
I like this light but I’m not at all blown away by its output. Just did some quick playing around with it and it does not outshine my Xeno Eo3 (and the Eo3 is NW). The output between the two looks about the same but the Xeno looks nicer to me because of the neutral tint. Comparing the two also made me realize again how much I like NW over CW.
This is my 1st ramping light and I really like that feature, however I agree with JonnyC the ramping is a bit too slow.
Overall for the price I’m not unhappy at all, it appears to have a good build quality, it’s sleek looking, and looks to have a decent quality finish.
I also had some weird flashing when I turned it on after removing the tail, tightened up the tail cap better and it went away.
EDIT:
After leaving both on high for 4 minutes the e03 got very hot and the C20 was barley even warm.
. EDIT EDIT: Not sure if that’s a good thing after reading this quote by JohnnyMac on a Crelant thread:“I just received a 7G2CS and it doesn’t warm up the least bit which tells me there is no heat sinking going on internally and the LED is cooking itself and, most likely, the driver as well”
Hmm, that’s strange, I’ve used it without grease for a while, it worked fine and it works fine with it as well. No problems with contacts or flashing for me.
Though I tighten all the lights well when closing them.
Didn't think it was worth mentioning before, but the tailcap on my C20 was not well tightened either, and the light did not turn on initially... all it took was half a turn to tighten the tailcap to fix.
My sample turn out to be 99,9% perfect, working like a charm straight out of the box, it was intended as a gift but when I saw it in person I changed my mind and decide to keep it :D
Now I wait T80 and Hong Kong postal system seems to be VERY-VERY slow this days :/ ...
If you loosen the tailcap about 1/4 turn you will see the turn on flash, it will blink once every time you push the tailswitch. So if anyone has that issue check the tailcap for tightness.
The tailcap threads were lubed when I got mine but the threads between the body and head were dry. I used SuperLube Synthetic Grease on them and now they’re smooth.
I’m really liking this light the more I play around with it.
I’m liking this light so much I’m considering getting the original Crelant version for the better tint (warmer) and slightly brighter. Either that or I need to learn how to swap this emitter for a NW XML.
Slightly brighter and warmer may have been worth the $15 more. But since I’m a sucker for a good deal I appreciate getting this for $29 and change.
You can get XM-L2 or XP-G2 from Illum. Supply and swap it. Reflow is dead easy you can check my latest thread for how do I reflow with just a soldering iron and a piece of metal/heat conductive material.
Rarely you can get NW tints from Chinese manufacturers, and if, then it’s most likely because the shop requested them or install the parts as selected themselves.
Of course you have to tighten everything
Not an issue for me. Yes I just tested it, you have to tighten the tail stainless steel ring as much as you can a 1/4 loosened turn makes it act up. For me it only works if I apply pressure on the switch or the ring when it is switched on because the switch board needs contact.
Thanks for the idea, that’s something I’d want to try someday, but I have never changed an emitter before, and I’m a little “in the dark” on exactly what your explaining here
I guess you’re explaining how to replace/build an emitter by soldering one on to a new “star” ?
Is the “Sink Pad” a “star”?
Does the C20 already have a SinkPad star or is is this something I would need to build in order to get an XML2 NW in to this light?
Guess I’m going to have to read up on doing this sort of thing and try building something for a “practice” project. I’ve got a lot to learn.
Yep, you will only need to solder the contacts and before that make the start smaller as 16mm is too big for a C20. Check the table at the beginning with dimensions.
Yes the tutorial is how to solder a bare emitter onto a star.
It’s definitely good to be a bit tech savvy when playing with things. You can find a lot on this forum on how to do things.
Goodness that was the best review I’ve seen so far. Thanks for all the time spent making it. Love the animated pics! That light is very interesting, been wondering when clones of these lights would show up. Def on my “want to buy list”
Thanks for recommending a more simple solution. I’m looking to mod it to a NW though, would this one be a good choice or can you think of something that would work better?
