UltraFire UF-009 Supreme
Reviewer's Overall Rating: ★★☆☆☆
Summary:
Battery: | Single 18650 |
Switch: | Reverse Clicky |
Modes: | High - Low - Strobe - Flood |
LED Type: | Throw - Cree XR-E , Flood - Cree XP-G |
Lens: | Fragile Glass |
Tailstands: | Yes |
Price Paid: | $43.75 |
Date Ordered: | 6/15/2011 |
Pros:
- Insane throw
- Some parts have good quality
- Nice flood light
- Can be made to take flat tops.
Cons:
- Some parts have shoddy build quality
- Unbelievably fragile lens
- Required modification to work right
- Doesn't take flat tops from the factory
Features / Value: ★★★☆☆
This light does two things and it doesn't do either unbelievably well. When I purchased this light, I was expecting to get a thrower that would blow my mind with the distance it covers. While it is a hell of a thrower, the light tapers off to the point of not being able to see it after about 130 meters. I was expecting to get something that would throw at least 250 meters. The flood light is the ultimate flood light. If you are a flood lover, this is the light to get on that alone. While it doesn't flood far, it floods EVERYTHING. An XP-G without a reflector will light up an entire wall, top to bottom, side to side from a foot away.
Design / Build Quality: ★★☆☆☆
To begin, I am going to start with the bad because the bad stuff is the stuff that really angers people. First and foremost, I had to modify the light with an aluminum washer to get it to work right out of the package because the head of the light would not make a good ground to the battery tube. After that was fixed, the lens broke! I don't know how, I have never broken a lens before. I guess because it was rolling around in my cup holder for a couple of hours was just too much for it to take. That really gets under my skin. It came from the factory with a haze over the lens that was blocking a good amount of light out the front.
The good things are really good. The machining of this light is amazing. Everything fits together really well and just feels solid. The anodization is without flaws and feels nice in the hand. The threads are standard threads but there are a lot of them and they are smooth! They came from the factory lubricated.
Battery Life: ★★★★★
Because of the design of this light, heat is a major concern. The engineers knew this and the LEDs are not driven hard at all. I am sure my AW 18650 would last a LONG time in this light. I will take current readings at a later date.
Light Output: ★★★☆☆
Maybe I am being too picky but this light just doesn't throw like I was expecting. The flood light is the only redeeming part as it is the ultimate flood light.
Summary: ★★☆☆☆
Overall, I give this light a two because of the issues I had with it. If I didn't have the problems, I would have given it a four because it is fun to watch peoples faces when you show this light to them in the dark. The beam that comes out of the end of this light makes it look like a light saber. It's a fun light and the dual modes make it useful too.
Pictures:
*I have included the aluminum washer I used to fix the bad ground in this image.
*If you take the brass plug out of the middle and flip it over (which it is here), the light will then work with flat top cells.
*This lens was broken when I woke up this morning. Absolutely no reason for this at all.
*Control shot
*My Spark SL6-740NW XM-L T5 light in neutral white (4B). The only thing that throws enough to compare.
*The UltraFire. This is 50 meters in distance.
