Unbranded Yellow 4 x AA Diving Light (Cree XR-E Q5 | 4 x AA)
Reviewer's Overall Rating: ★☆☆☆☆
Summary:
| Battery: | 4 x AA |
| Switch: | Magnetic side switch (Turn lever) |
| Modes: | 1 |
| LED Type: | Cree XR-E Q5 |
| Lens: | Plastic, TIR |
| Tailstands: | No |
| Price Payed: | $11.70 |
| Date Ordered: | June 2012 |
Pros:
- Seems to be water tight (didn't test in deep water though)
- Lightweight
- Uses easily available AAs
- Yellow color is easy to find also underwater
- Double O-rings
- Lanyard included
- Comes in a nice box
Cons:
- LEAKS!! (Noticed after review -> Stars dropped from three to one)
- Tight for some AAs (Eneloop XX fits barely, got stuck in the tube)
- Build quality varies
- Light output with alkaline AAs
- Switch lever doesn't feel robust
Summary:
| Battery: | 4 x AA |
| Modes: | 1 |
| Tailstands: | No |
Pros:
- Lightweight
- Double O-rings
- Lanyard included
Cons:
Features / Value: ★★★★☆
The light comes in a nice box.
In the box there were the light itself, a yellow lanyard, and four AA alkaline batteries (even though the page says batteries not included, so this might be a mistake at their end - YMMV). Operating instructions are printed in the inside of the box in bad English.
Main features are: Waterproof (for diving, 50m by manufacturer specs). That's it, nothing else.
UI is easy: Turn the lever to either direction and the light turn on. Turn back to center to turn off.
Here's a photo of the lever in on-position.
Off:
Value for money: Ok.
Design / Build Quality: ★★☆☆☆
Design is actually good. Clear functional form and no nonsense.
Build quality varies. My sample was quite ok, but the TIR optic was "interesting". Maybe the emitter didn't fit and someone decided to grind the optic to make it fit? There were also some glue marks in the front of the optic. These resulted in a ugly asymmetric beam pattern.
Also the bottom of the driver did show some (corrosion?) marks:
Let's see some more details..
The body tube with plastic threads and double O-rings. This is the only threaded connection in the light.
A flashlight requires some kind of lanyard for diving use, so there is a good place to securely attach the lanyard to the light.
Inside of the body tube: Not much, only thin metal plate with springs.
The pill is just dropped in to the body tube. Asymmetric slots guide it the right way around (for correct polarity). Note also the battery polarity chart on the wall of body tube.
The place where switch is located. Nothing comes through the tube -> switch seems to be magnetic.
A photo of the light disassembled:
Some measurements:
Length: 166mm
Head diameter: 42.2mm
Body size: 23.8 x 35.6mm
Weight: 224g with four cells and lanyard (= ready to use), 105g without
And the bottom line in the quality: Too many flaws in a simple light.
Battery Life: ★★★★☆
Manufacturer promises "more than 120min". I didn't measure the TC currents / runtime yet, but my calculations based on output tell that the runtime should be near five hours with Eneloop XXs. I'll come back and update this section with better data later.
Light Output: ★★☆☆☆
This light is driven low, most probably because the heat issues (and of course you can say "it's optimized for longer runtimes", which is surely needed when diving). The hotspot size equals to well known C8s and there is very little spill.
I estimate (ceiling bounce + "known" references) the light output to about 120 lumens
Couple of white wall beamshots (WB: Daylight)
Ringy and asymmetric beam (doesn't look that bad in the photo - way worse in real life!)
Beam pattern
Couldn't take outdoor beamshots due the lack of darkness. Sorry about that.
Summary: ★☆☆☆☆
Cheap flashlight with no nonsense. Seems to be suitable for diving. Not-so-good / random build quality is a minus, but if you get a good one it's definitely worth the money.
Edit: I also noticed after writing the review that this sample also LEAKS from the bottom of the tube. I didn't notice it when doing the preliminary water proofing tests, maybe because the lanyard was partly blocking the small hole(?) I took the lanyard away to see if the light would float (it didn't) and immediately noticed some drops of water in the battery compartment. Maybe all these $8-15 dive lights from eBay / sellers like verosale.com are really factory rejects? (of Poplite?) That + failed testing would explain the corrosion in the driver as well..
Verdict: Not recommended! (= buy only if you want to gamble and/or love discussions with customer service)
The End (pun intended):
Thanks for reading & watching. Hope you enjoyed the review!
