The Low-Lumen champ
Sunwayman has a reputation for producing high quality flashlights, with this “V11R revolution” being one of them!
After buying the V11R Mirage, with its older XM-L U3, I decided to buy the upgraded V11R XM-L2.
Let`s move on and see if and\or what kind of differences there are between the 2 lights.
Specifications:
- Brand/Model: Sunwayman V11R revolution
- LED: CREE XM-L2
- Working Voltage: 0.9-4.2V
- Battery: 1xAA/14500 1xCR123A/16340
- Switch: Forward clicky (tail cap)
- Modes: Infinitely variable 1-100%
- Mode changing: Magnetic Control Ring
- Anodizing: HAIII black
- Tail stand: Yes
- Lock-out: Yes
- Momentary-On: Yes
- Coated glass lens: Yes
- Reflector: OP
- Waterproof: IPX-8
- Shop: Wallbuys.com
What you get:
Rather than the tin box that I got with the Mirage, this time they have the V11R in their normal style packaging..
Nothing fancy, and a kind of cheap looking... for the money they could have made a better box!
- Simple package
- Holster
- Lanyard
- 2 Spare white O-rings
- 1 Spare metal clicky!
- A Spare rubber boot
- Papers (warranty card/manual/brochure)
Dimensions and weight: (Identical to the V11R Mirage)
AA style: With AP-05 extender (optional, not included in the package)
Length: 100mm Diameter: 23mm
Weight: 59grams (without battery)
CR123A style: (without extender, without battery)
Length: 85mm Diameter 23mm
Weight: 50 grams
There are some noticeable differences cosmetical wise:
First of, it`s obvious that they are identical in size and structure. But there are some noticeable differences as well., besides the color....
- The Mirage has no Output labels below the control ring, which makes it impossible to see in what output level it currently sits
- The revolution has labels with Min and Max, with an indicator on the magnetic control ring to see in what level it currently is
- The reflector on the Mirage is slightly more aggressive OP, with the revolution having a smoother reflector.
- The revolution comes with a spare metal switch, which looks great!
- The revolution has more and different text on the body.
Handling and Close ups:
Using this light is a real pleasure.
Not only because you can use its variable output magnetic control ring, (I LOVE IT) but also the size and fit.
It`s hefty and robust enough that you can hold it in a fist, while not being afraid to damage it if you drop it or bump it on a hard surface.
It has enough and well done knurling , and including the clip its easy and comfortable to handle, even with 1 hand. Knurling is aggressive enough
Compared to the C10R (CR123) and Convoy S5
The positive contact to the head
Spring in the battery tube
Well centered XM-L2
AR coated lens
- The thing I like a lot about Sunwayman lights, is that they have the rear switch in combination with the magnetic control ring.
It also makes this light able to do morse-coding with its momentary-on. And it will not have any paristic drain (my main point), which could result in a dead battery after a long time not using the light.
The anodization is of excellent quality, I believe.. as I`m not going to test that...(yet)
So far I haven`t seen any blemish on the anodization, just like I haven`t seen that on any of my other (10) Sunwayman lights.
One thing that need to be said is this, and is a Con:
In combination with the AA battery extender AP-05,the light could be turned off accidentally while turning the control ring...
But this is quite rare.. and usually can happen when wearing gloves, when its`s difficult to “FEEL” the beginning and end of the movement of the control ring.
Unlike the V25C (18650) which has a 360 degrees variable control ring, this Sunwayman V11R revolution makes it possible to turn it to High as well as in Moon-mode,(you can move the ring left or right), without watching.
The V25 is just impossible to Feel or See in what output level it sits in Off mode.
The main reason I only used it for about 10 minutes before I sold it.
The magnetic control ring has enough grease, so it moves smooth and with the same sensitivity.
Comparing this to the V11R Mirage, it feels much better..
Mainly because the Mirage sometimes spins a little (with increasing/decreasing output, depending on how you push the ring, up or down. That is something I just noticed now, while I first thought that was normal with the Mirage... now I know that it isn`t.
The prints on the light are good but not as clear as I hoped for.
This could definitely be improved on future Sunwayman products. I already noticed that on the M10A I have, and they haven`t changed it much over the last couple years.
The Mirage has different style prints, and look to be made in a different way, or at least in a diffferent font/size.
See here for the mirage prints;
Here you can see the prints are different, including the indicators of Min and Max output
And with and without the AP-05 extender, for using it with AA batteries.
Modes: infinitely Variable
How? Just turning the ring from Min (sub 1 lumen) to max (approx. 500 lumens with 16340)
No blinkies! yep, they are impossible to find!! they are just not there!
I can`t praise these variable magnetic control rings enough..
Even if its pitch black, you can turn it on in the lowest or highest mode, with 1 hand.
I use the V11R Mirage as a bed-side light, and its great...
Love it!
The only negative side it has, is that it draws more current with same output than other lights.
PWM:
None:
not in Low, not in Max, nowhere.
Medium:
Low:
Performance:
This is what most people are interested in.
(while this is a main factor for flashlight users, you should not overlook some other very (maybe even More) important aspects of a light: size/ modes/ anodization/ handling/ tint/ accessories/ upgradability/warranty etc)
First the different amperage drawing used with different battery types, and then some run-time test and beam shots, to see if anything has improved with moving to the newer XML2 from the standard XML.
Numbers:
Output in lux (Ceiling bounce!) not throw. Note: These numbers are not here to compare to other people`s lux numbers.
They are only to compare with the other lights I tested with the same setup and same conditions.
Setting on my HS1010A light meter is x2000
For Lowest mode,a ceiling bounce is impossible, so I shine the light directly on the white dome of the Lux meter.... so the numbers between Max and Min can`t be compared.
I really want to insert a table here;;;; grrrrrrr
- AA eneloop @ 1.3V
Max (ceiling)
Revolution XML2: 20 @ 2.3Amp
Mirage XML U3: 14 @ 2.2Amp
Min (direct)
Revolution XML2: 4 @ 0.04Amp
Mirage XML U3: 0 @ 0.04Amp
Somehow the light meter just showed 0...I`ve tried it a few times, but it stayed at 0
First pic XML U3 Mirage
Send pic XML2 Revolution
- 16340 Trustfire flames @4.24V
Max (ceiling)
Revolution XML2: 88 (64 after 30seconds) @1.55Amps
Mirage XML U3: 76 (66 after 30 seconds) @1.64Amps
Min (direct)
Revolution XML2: 13 @0.014Amps
Mirage XML U3: 4 @0.015Amps
- CR123A Panasonic @3.2V
Max (ceiling)
Revolution XML2: 28 @ 0.84Amps (28 after 30 seconds)
Mirage XML U3: 28 @ 0.8Amps (27 after 30 seconds)
Min (direct)
Revolution XML2: 5 @ 0.02Amps
Mirage XML U3: 2 @ 0.02Amps
- 14500 Trustfire flame @4.18V
Max (ceiling)
Revolution XML2: 78 (66 after 30 seconds) @1.55Amps
Mirage XML U3: 77 (71 after 30 seconds) @1.85Amps
Min (direct)
Revolution XML2: 7 @ 0.014Amps
Mirage XML U3: 2 @0.014Amps
Comparison with other lights on Low: Same camera settings:
- ITP A3 eos titanium XPG R5 (AAA) (supposedly 3lumens)
- Sunwayman C10R XML (16340) (supposedly 3lumens)
- DQG Tiny 26650 XPG2 NW (26650) (supposedly 4 lumens)
- Fenix LD12 XPG (AA) (supposedly 3 lumens)
Beamshots:
Control shot:
Conclusion:
The difference between the 2 lights is not enough to really say that the V11R XM-L2 is an improvement over the older XML U3.
Switching on both lights will give a little headstart for the revolution with its XML2, but after a minute the Mirage holds its own..
Not sure the reason, maybe the higher voltage the XML2 needs? Or thermal conductivity is better on the Mirage?
PRO:
- Fully adjustable brightness with Magnetic Control Ring (MCR)
- Great machining
- No sharp edges
- Anodizing is great
- many battery options
- No PWM
- Indicators for Min and Max (that are not on the Mirage)
- Extendable with AP-05 sunwayman extender for use with AA /14500 batteries
- Bright on 16340
- Control ring has enough grip, much better than the older Sunwayman M10A and V10A
Cons:
- 10% drop in output within the first minute
- Price, not budget
- Sometimes switches off, when turning the MCR too powerful (breaking contact/lock out)
- O-ring that came with extender was too thick (this is not part of the V11R set) and didnt make good contact
- AP-05 extender is optional, and isn`t cheap
- Draws more current on identical output than others (but they don`t have a magnetic control ring)
