Hi all, Father’s day is around the corner ( another excuse to put on a group buy :bigsmile: ) and it’s time to save up some money on this great little light Sunwayman V11R
Review is here
Available in CW or NW
Here’s a little info on this light
he SUNWAYMAN V11R is one revolutionary compact and extensible EDC flashlight. This light is compatible with one single CR123A (RCR123A, 16340) or one single AA (14500) battery with the optional AA extender. Powered by one 16340 or one 14500 (only when with optional AA extender), this light generates up to 570 lumens (Do not run the light continuously at this max mode for more than 5 minutes).
Utilizing SUNWAYMAN’s signature Magnetic Control System (MCS) in combination with our new fully variable output circuit, users can select any brightness desired from 1 to 570 lumens. The exquisite tail cap metal push button design and structure, as well as the intelligent and easy-to-use user interface, makes the SUNWAYMAN V11R an ideal lighting tool for every-day-carry, outdoor activities and to take with you on the road.
Specification:
Product name: Sunwayman V11R CREE XM-L2 LED Flashlight
Brand: Sunwayman
Model: V11R
Emitter Brand/Type: CREE
Emitter BIN: XM-L2
Material: Military Specification Type III- hard anodized body
Mode Dimming from 1lm to 500lm
Battery Configurations: 1 x CR123A Lithium battery or RCR123A, 16340 battery
Switch Type: Clicky(Tactical forward click switch with momentary on)
Switch Location: Tail of the flashlight
Brightness: 570lm
Carrying Strap: yes
Carrying Clip: yes
Lens: Ultra-clear tempered glass lens resists scratches and impacts
Circuit Broad-voltage better compability
Range: Effective range of 130 meters
Working Voltage: 0.9~4.2V
Waterproof in accordance with IPX-8 standard
Color: black
Weight: 49g
Size: Dimensions: 84mm (length) x 23mm (head diameter)
Features:
- Equipped with broad-voltage circuit, the V11R is compatible with various voltages batteries with the same specification as well as guarantees the high efficiency of the circuit system. V11R can satisfy your demand of battery universality and makes no waste.
2. The V11R comes with two switches assemblies, one of which is the Ti switch, the whole tail cap push button is particularly made of metal, clear labeling, beautiful, practical and durable, which highlights the outstanding texture and the design aesthetics; the other is the traditional rubber switch, which is soft and easy to use. Users can always choose the one you are comfortable with and have the other one as backup.
3. Digital Sensor Magnetic Control system, Infinite Variable Output Switch- slightly twist the Rotator Ring from left to right for Min to Max output.
4. High quality OP reflector maintains great throw distance and spread with an ideal beam pattern
Not sure about if there’s MAP on this light… but for sure the price will be a lot lower if we can get more than 50 but even if we can’t get 50… we’ll have substantial saving on this light ( even if it’s only 20 )
For now, anybody who interested in this light can pm me for the price or post in the thread ( even if you just consider it ) so we’ll know how many people have interest in this light and they will adjust the price accordingly ![]()
EDIT Got the clearance to post this price safely now… so here are the prices ![]()
1-20 price: $49.99
20-50 price: $47.99
50+ price: $45.00
EDIT OK guys…after some “discussions” we get some agreement, here’s the coupon for the group buy BGV11R price will be $45 but it will be limited to the first 20 people ! so hurry and get your Sunwayman V11R now! ![]()
