Z1 Artemis TIR, Void White
62 USD
FFL5009R 2700K ROSY CRI 95
5 USD
Including free shipping(may depends on region)
Thanks to @Fireflylite-Ivy, I could purchase FFL5009R 2700K ROSY CRI 95 version of it.
This is First impressions, after 1 hour 30 minutes from unboxing.
Packing: Not that premium feels. Red Chinese style paper box looks cool anyway, appealing their origin is way better than concealing or hiding it with confident. But flimsy plastic cradle inside is not what I like. Just roll it with foam will be better.
First look, It’s white!
White means nightmare and cost to manufacture. But as consumer, I love it. Brighter color means they don’t quickly heat up under sunlight like darker ones.
Threads are nicely anodized with black.
But no lubricant on it. Adding grease make real difference. Also prevent O-rings from wear out.
I used, Calcium sulfonate-based grease on it.
Also White on black Ano suggests it might be some types or powder coat.
Stock clip does not clip at all, it’s more like pocket hook.
But simply put it reverse and bent slight amount will just fix it.
Tada!
AR coating is nice. Single sided AR coating with purple tint, almost no reflections are shown in side.
I prefer double-sided AR coats for maximum optical transparency, but once it pills off, plenty messy. It’s debatable, but one side(inner) AR coat is nice choice.
EDIT: I forgot it was TIR, so not sure about this
And surprisingly, when I put the battery, it never turned on. Yes, with two different confirmed battery it never turned on, there was any sign of life.
→ tail cap open, tighten it well.
Tail cap side of Z1 Artemis tube shows thin O shape contact, I prepare bit larger contact points for stability. Just like head side of it.
I also recommend apply light films of grease or oil on contacts to prevent oxidation. Especially this model states Ag plated for springs. But under dusty environment, you should constantly clean and reapply.
Finally AUX lights glows, got the fire.
Fun starts!
This is my first experience for the Anduril 2 UI
AUX looks so charming at the first place, way more than I thought. I’m not the AUX person, I never ever imagined I can enjoy it.
After some sensations gone, I turned off AUX and set some.
Ramp range 1 - 60
(May add some for ceiling, 70 or 80 some day)
Ramp speed 4th
Temp regulation 40°C ← Caution
(Not sure it regulates well)
Edit: See → What you got today - #12262 by jon_slider
Post-Off Voltage Display OFF
(OFF - 3C - batt check - 7H - 2nd flash - 0C(Leave it))
WOW.
@ToyKeeper is god.
- I can set freely and exactly set the brightness level I want.
- Ultra low level is possible. IDK about runtime, seems it can stand 4 x Seven days as the moon light mode as It’s original term. *Month in Chinese character is 月, which means the moon. Fireflies are flashing, and way brighter than the moon’s steady light
- It just works with one button simply.
JUST AWESOME!
I should figure how to lock turbo for safety, but think soon I can.
_
25.5°C (77.9°F), RH 50%
Battery: 4.062 46 VDC
Around 10 μADC (near noise floor of tset environment, meaninglessly low for this set up) @ 3.70 VDC tail cap when off.
But the problem: It was tested with 10A mode. I blowed 3A fuse, so sub μADC test ability at 3A mode is gone until replacement is come. Also It is bypassed the tail cap and heavily affected by contact resistance due to probing error.
_
This is my first ever Rosy, Sub 4000K try.
The FFL5009R 2700K ROSY CRI 95 Emitter!
Compared to Nichia 519A R9080 4000K CRI 90+, it looks promised rosy beam!
It’s.. Nice!!!
Bonus!
What we got from decades of development.
Difference is significant.
Thanks for reading
