Hi everyone, I am developing the new Rey Engine. As you all know, ReyLight is a community driven brand, and your support and input are essential to its development. I want to make products to fit your demands as much as possible, and I want to gather your opinions and ideas about the groups in the new driver.
Since the output of the flashlight ranges from 1% to 100, I want to know your preferred output spacing. (LAN and Pineapple is moonlight-2-20-100). Since there will be secondary light in one of our upcoming flashlight, I also want to know where you want to put the secondary light. There are certain functions such as strobe and strobe frequencies that I am built into the UI.
Here are some thoughts:
Config:
8+ clicks to enter configuration, it will give 5 solid flashes, each flash stands for a given function.
Config #1-5 (or more)
1.Select a mode group, from G1-G8, (or more)
2.Mode memory on/off.
3.Moonlight mode on/off.
4.Reverse mode order, L-M-H to H-M-L.
5.Reset.
6.Your input here~
Mode groups:
Red or white fast strobe,
Red or white slow strobe,
Red or white random/crazy strobe,
Red or white SOS,
Red or white beacon,
Red or white beacon with white or red background,
Alternation of white and red strobe with background,
Red or white heartbeat strobe,
Red or white breathing,
Please comment in this format.
Such as:
1.Red25- red100- white2% - 25% - 100%
2.Red100- white100
3.White100%- white strobe
4. red25, red100, wht50, wht100
5. 1, 20, 50, 75, 100
6. 15, 40, 75%
Hidden group: When the light is on, press and hold the switch for 1.5-4 seconds.
This can give you a quick and direct access to a special mode group, such as strobe, beacon, etc.
