I just received a Rustu XL-03 from Dealextreme
My initial impression was good. This thing is tiny. It’s slightly shorter (comparing both lights with bezels retracted) and MUCH thinner and lighter than an SK68. It’s even thinner and lighter than an SK58. The beam profile is also very similar to an SK68, with about the same width in flood mode and the same spot in spot mode. Opening it up I found the following:
Lens diameter: 15-16mm from the front. The lens is smaller than that on an SK68, so I’d expect spot mode to be slightly dimmer if the emitter and driver were the same.
Emitter: Cool white Cree XPE
Star: 14mm very thin aluminum. Zero thermal grease under the star.
Driver diameter: around 14-15 mm (same as a Sipik 68), but the body tube around the pill is narrower than the Sipik.
Pill type: Aluminum, with a solid platform under the LED. There are 2 holes in the edges of the pill for snap ring pliers (or a large paperclip)
Tailcap: standard cheapie switch held in place with press-fit plastic retaining ring.
Clip: removable. Held on with a ring around the tailcap behind the o-ring. Unlike most clips, this one cannot slip off as it goes all the way around the tailcap.
Switchboot: 12mm orange color
Tailstands: yes
Not bad for a small zoomie … similar performance to a Sipik 68 in a much more pocketable size. It feels like it’s half the size of the Sipik!
Modding potential:
Of course, I’d never stop with an unmodded cheapie zoomie… so I spent some time last night doing a quick mod to it. I performed the following mods:
1. removed the driver and replaced with a 2.8 amp 3-mode Nanjg 105c I had laying around. When I mod Sipik 58s and 68s, I’ll file down the edges of the driver and then glue it to the bottom of the pill with arctic alumina. I attach a bit of solder braid to the ground ring and drape it alongside the driver so it hits the threads.
2. Since the body tube on the Rustu is narrower, more filing was needed. I almost completely filed off the ground ring around the edges of the driver, and then filed the corners of the 7135s near the edges of the driver. I did this until it would slide cleanly into the body and fit at the end of the pill just outside the original driver socket.
3. For negative connection I soldered small pieces of solder braid to the ground tabs of 3 of the 7135s near the edge of the board. When the board is pressed into pill, the edges of these braid pieces hit the inside of the pill making ground connection. I then glued it to the bottom of the pill with arctic alumina. After repeated assembly and disassembly the arctic alumina didn’t hold, but turned out not to be necessary since the pressure from the battery acts to press the driver into the pill and gives a good connection.
4. I replaced the cool white XPE with a 5000k neutral white XPG2. I used the stock aluminum star, but added AS5 thermal grease underneath. Some time when I have more time, I may try filing or sawing down a 16mm Noctigon or Sinkpad to fit, but I figure that will take awhile.
5. I bent a small strip of aluminum into a “C-ring” and fit it around the top of the pill threads. This ring keeps the pill from socketing fully into the body. It’s purpose is to increase the travel of the bezel and allow the emitter to sit closer to the lens in flood mode for a wider beam while not affecting spot mode.
6. I replaced the driver spring with 2 small copper disks.
Result: It’s now a 3-mode XPG2 light. Much brighter than stock, with similar throw and a wider hotspot. I’m running it on Kinoko IMR 14500s from Illumination Supply.
Additional mods I might make to this light:
- Cut down a small reflector from an old UKE lamp module. I’ve done this in the past with zoomies. It adds a large hotspot to the flood beam, making for a much more useful flood. It also adds an ugly donut around the spot in spot mode, but the donut is dim enough it’s really only a factor in white wall hunting and doesn’t affect real-world distance viewing.
- Disassemble the tailcap and solder-braid the spring. Also change the orange switchboot for a black one.
- Replace the 3-mode driver with a 4-mode one that has moonlight.
- Replace the stock star with a direct copper star that has been filed or cut to 14mm. This may also make it necessary to readjust the focus on the lens as it would be much thicker than stock.
I also received a second light from DX that looks very similar to the Rustu:
Another 14500 zoomie
This one is the same size with the same basic dimensions. The parts are interchangeable. However this one has the following differences:
Driver: 3-mode (100–50-strobe)
Emitter: Cree XPE, slightly more neutralish tint than the Rustu
Pill: seats a 16mm star, but it’s hollow. Also this pill has an oddity: look in the top of the light and there are no holes for snap ring pliers to unscrew the pill. I ended up drilling holes in the plastic disk and using those to unscrew the pill.
Bezel: same shape, but external styling is slightly different.
Body and clip: body is same shape, but clip slips into a slot in the side of the body rather than being a ring around the tailcap.
Tailstands: No
I concluded the Rustu is better due to its tailstanding and solid pill.
