@WarHawk, hmm… I think the design do not need knurling on the middle pipe?
@Simon, check pm
@Simon, check pm
Actually the knurling ain’t too bad, I just like the very small size of it, and even at 1400 mA (4*7135 w/ a XP-G2 T6-4C) it throws a decent amout of light, and at that current level, even on high the small 18350 should run comparable to a much larger 18650 at 2x the current w/o the heat problem
did you upgraded it to xp-g2 emitter? how nice compared to xm-l2 ver?
and is it safe to use rechargeable 16340 li-ion battery?
Simon, do you know if the 18350 body fits your current stock of 18650 s2+’s?
I think it comes stock with a XM-L2…mine has the nice silver XM-L2 T6-4C in it
the 18350 would fit better, it’s designed for it, a 16340, you might need to wrap a strip of electrical tape around the battery or it would be loose…not sure about the CR123 version though…might be thicker walled
ow I see, a weird first 18350 tube format flashlight maybe? lol…
It’s all about vape batteries… do you smoke @WarHawk?
not anymore (did for almost 20 years)…since I started vaping, haven’t touched a stinky since Aug 1, 2013 ![]()
Vaping is what brought me to BLF
Had to have something to put the “not good enough for vaping” batteries into ![]()
Ah, I had lost track of this nice host. But christmas is coming nearer…
WarHawk,
could you - or anybody who has the light - please confirm whether there is a color difference or not? To be honest, when I look at the pictures there seems to be a difference in tone. I hope it’s not.
Thx in advance.
Mine is silver and the colors match
That’s good to hear.
Thx WarHawk ![]()
Nice!
will you sell just the battery tube ?
1+
Wonder if you can squeeze a 18500 in it ?
Maybe if you mod it to a twisty like comfy has done with some lights…
No go on the 18500, very tight fit with 18350.
Now…an 18500 battery tube as a 3rd option would be pretty nice…hint hint Simon ![]()
They mean if the tail switch was removed and the tail bored out to 18mm if needed. Convert it to a twisty
Possibly…
Looks like you need an extra 12mm in length in the battery compartment to fit an 18500.
I think this should be possible without removing the switch. You’ll need to do the following modifications:
All these mods should be possible with just a handfile and several hours of time. No machine tools should be needed. When my second light arrives, I think I’ll try the above mods on it.
All the modifications mentioned above +
Can a 18650 fit in there?
Or 2x 18350 for the world’s smallest MT-G2 semi-mule… that’d be awesome. Instead of opening up the reflector, it can be sand down from the bottom, up to half in height for 6mm extra.
