Hey guys! So i built an s2+ with the old xhp50 and xhp70 aswell, but the xhp50 seems bright enough for me and fits better too. I liked the light and everything, I was using a modded fx-17A driver at around 3.5-4amps, using 2x 18350's. Now I got so tired of the poor batterylife of the 18350's, so I was thinking what if I fit an H1-a boost driver to use a single 18650? it fits in the head fine, but would need to solder it underneath the pill somehow or make some sort of adapter! I will be using the stock pill and a 16mm kd board xhp50.2, 2600 lumen should be plenty for me. I know the pill and light itself isn't great at cooling, but I would only use high modes in bursts and lower modes otherwise, it seemed to work good enough at cooling with the xhp50/70 using a fx-17a. What do you guys think of this doable? How would I go about doing this? This idea just came to me lol! What do you guys say?
Can’t help with the question you have hannesremo, sorry, but I’d like to ask you which reflector did you use with those leds! Did you use the stock OP or SMO reflectors from Convoy S2+?
Thank you and good luck with the mod Show us some pics then
Some 20mm x 1mm brass or copper tube might work cut and filed to size and soldered.
I did make a carbon fibre light with an MT-G2 and H1-A driver which works fine but like you said just watch it on high mode although your aluminium host will handle it better https://budgetlightforum.com/t/-/45871
Because there’s no other way to secure the driver.
Even in a stock Convoy the double-sided (Nanjg 105) drivers are soldered to the pill at 2 spots on the edge.
I believe only the single-sided (AK47) drivers were secured with a threaded retaining ring.
The stock S2+ driver cavity is only 17mm, but the H1-A driver is 20mm. hannesremo said the driver will fit into the tube of the head, but not down into the stock 17mm driver cavity in the pill.
So a method of fitting and securing the driver to the pill is needed because it’s not going to just fit in like the stock driver.
Lowtech replied that he used a dremel to fit the H1-A, but he didn’t specify if he resized the driver itself or widened the opening in the pill, (or maybe he did both)
CRX suggested using a piece of 20mm x 1mm copper or brass tube cut and filed to size and soldered. I assume he meant tubing with a wall thickness of 1mm, to create a new “ledge” for the driver to sit on. I think the driver can’t sit on a ledge much wider than 1 mm to avoid contact to the components that sit near its edge.
Sounds like a tedious job either way, I’d like to know what hannesremo did, if anything yet.
I should note that the Nichia 144 dies have a little bit of an uneven phosphor coating, so I recommend a TIR optic to help smooth out the light to avoid the 'fried egg' yellow centre portion of the beam. The result is very even and nice :).
Also works with a heavily textured OP reflector, like the one in my Haikelite MT01, the beam is just beautiful. I love the tint, high CRI, and deep red saturation.
When I’ll have the copper washers, I’ll finally post the mod on BLF.
BTW loneoceans, if I remember, your boost driver is open source, yes?
Absolutely! Once it's done it'll all be up and hopefully documented! I'm still changing things here and there at the moment, but all the basic functionality seems to be good. Meanwhile do check out my previous GXB17 and GXB20 projects - both the threads and my webpage have hopefully a lot of detail on how they work :), so I'll be doing the same for these new drivers.
I read something in another thread today which gave me a new idea for this mod, for the issue of securing the H1-A driver.
I could get an 18350 tube (around $2.00) and cut off a short ring from the end of the threaded portion, make a few tool notches in it (for installation/removal) and use that as a retaining ring, it would be real thin too, so it should clear any components near the edge of the driver.
