The topics were likely a bit hidden in Modding and DIY category
TA drivers series check this topic
clicky and momentary firmware available (Bistro OTSM and Narsil)
13-15.5$
15mm, 17mm, 17-19mm, 17mm Oslon Black flat, 20mm , , ,
new 17mm for 2 S eliminating AMC7135 dedicated indicator resistor and pad
2 channel (Narsil with indicator) , 3 channel (Bistro HD)
new types , ,
20mm Oslon Black flat, 20.5mm Astrolux S42, 21mm, 21mm Skilhunt H03 , , ,
Possible for sure
this 2 Buck driver needs cooling at high output levels, so a board that fits the host is important no piggyback
I can simply enhance the outer diameter to a larger size like 49mm, add mounting holes for different drivers then sanding down to the needed size
One thing for more host compatibility is to collect detailed information about the hosts driver fitting,
diameter is one thing,
but another is clearance where no parts are allowed, including more clearance near the screw holes
mounting holes,
height of the parts maximum, cables that decrease that height might be an issue for the 6mm high inductor on some lights like MF02 that have only 9mm depth
Then there are basically 2 light typed with battery carrier and ones with tube
Battery carriers make things easier for sure
Wait, buck drivers? Looking to build a drop in for one of my C2-HA Centurions would any of them support 2xCR123/2x16340/1x16650? What would work best with the z41 momentary switch?
