To me with factory stock 2022 anduril it drops a lot, but I did not give it importance because the TS10 is too small to dissipate the heat.
It also happens to me with a normal level a few minutes later it drops very suddenly, the truth is that for long rides it is useless unless it is at very low levels.
I put the last one on the 12 of 2023 and raised the temperature ceiling to 55° I think this temperature should be the default and not 45°.
I have yet to test how much it drops.
Look at a graph but with the comparison of the TS30s Pro with the L21B not with the L21A I do not know why everyone uses the L21B for me it is a very ugly design, but that is the taste of each person, I see the L21A more efficient with those fins than the B and more beautiful to the eye more pro.
And the TS30s Pro is put very bad a few seconds or minutes falls below 600lm.
It is an outrageous loss that has, instead the L21B (does not leave the A) loses much less and lasts much longer with that level I seem to remember that went down above 1000lm is little but it is no longer 500 or less than 600lm of the wurkkos.
It is something that is talked about in the review I see of the TS30s pro, it seems that it is not very good in this regard, so never buy it but it is the one I like the most besides not having to remove the battery to charge it.
By the way the best for me is the Convoy L8 with the same led this if it is a good flashlight, but I never see it on offer as ls Wurkkos TS30s Pro or Convoy L21A that many times is on offer.
Now I can buy one of the two and the convoy for 4€ more than the wurkkos or the L21B cheaper than both, the only thing I do not like the design as I say is ugly to my eyes and I do not see it with a good design to dissipate heat.
It would be interesting to know if it improves the TS30S Pro by raising the temperature ceiling in anduril to 60° for example.
Thank you for your review, it helps me a lot!!!
PS: In this same review you can see the drop after a few seconds, in the review I saw and do not remember, the measured values of both flashlights are shown in more detail.
