Interesting that this comes up. I was reading about this scooter just a few weeks ago.
I have seen methods similar to this battery pack used.
This is more or less a ripoff of Jehu Garciaâs PCB powerwall designâŠeven using the same cell holders (what he calls the HP-High Power version, which is true, these Keystone cell holders are the best out there by a long shot, all the others add quite a bit of resistance due to their shitty metal leaf springs or even worse, traditional wound springs like youâd see on devices that use alkaline batteries. I tested various cell holders with my RC3563 and found that these Keystone cell holders only add something like 7mΩ of resistance on each side which isnât great but isnât as bad as the other cell holders with the pins that add something like 17mΩ on each side.)
I am kind of confused by the manufacturers claim that this is a high current application so it is necessary to use NCR18650GAâŠdonât get me wrong they are the best 3500mAh cell and have a 10A discharge unlike the Samsung 35E but the LG MJ1 (the newer version, not the original release) is definitely neck and neck with the NCR18650GA.
I would guess that they are afraid people are going to try to use salvaged laptop cells that had a max discharge rate of maybe 4A when new and now canât hold more than 2.5A continuously. Seems like the energy density of these 3500mAh cells is necessary to get any useful range but a decent load is also drawn from the cellsâŠperhaps as much as 5-7A? Running these cells any harder is BAD BAD news. Theyâll get well over 60 Celsius if you are going around giving frequent bursts of full power, say at a 50% rate.
While I admire their desire to make the battery pack user serviceable and think their PCB design is actually pretty slick I really canât recommend using ANY type of cell holder for an application thats going to draw more than 3A for your typical pin type cell holder and 5A for the Keystone cell holders. The increase in resistance is just too much. Iâd be really curious to see how hot the pack gets and if being in a container submerged in water provides any extra coolingâŠI would guess that the plastic used isnât the best at transferring heat in the air surrounding the cells through the plastic into the water but I could be wrong.
With the groups of cells only testing in the mV range they are definitely dead and for such an application it is absolutely not worth the risk of trying to recover them and reusing them in this applicationâŠfor some other projectâŠmaybeâŠbut they likely wonât recover and if they do who knows how bad the self discharge will be.
When I read how long it had been since the pack was shipped I instantly knew the cells would be dead. Look at the (land) scooter batteries Jehu Garcia sells. They sit for less time in warehouses and the BMSâs absolutely flatten the packs in some cases. If its been less than a yearâŠyouâre probably going to be fine if the cells were at >3.50V when shipped (~3.50V seems to be every manufacturers shipped voltage).
OP, I know you want a safe pack but I would seriously consider taking a look at BatteryHookup.com and see if thereâs anything on there. Unforunately the only thing I can think of is the packs of LG M50LTâs but those are 21700âs. Youâd pretty much HAVE TO find either LG MJ1, LG MH1*, LG HG2* Panasonic/Sanyo NCR18650G, Panasonic 18650BD*, Samsung 30Q*, Molicel M35A, EVE 33V*, Sony VTC6*, Sinowatt 35HP, Sinowatt 30SP*, Sinowatt 34MP*, etc
The cells with an * are 3000mAh or better but not quite the â3500mAhâ rating of the cells without an *. And those â3500mAhâ cells are often more like 3350-3450mAh cells. They all do have a max discharge rate of at least 10A and the slightly lower capacity cells mostly have a discharge rating of MORE than 10A which would allow them to run with less voltage drop. So if this scooter is pulling as many amps as I think it is, the higher discharge rating of some of the 3000mAh-3200mAh cells would mean they would probably give you almost equal range to the â3500mAhâ cellsâŠand perhaps run a tiny bit cooler.
Another option which I highly suggest you consider is the Molicel P28A or P28B (more expensive) The 28A can be had pretty cheap when youâre buying 100+ and its discharge rating means it will run quite cool in the scooterâŠbut its a 2800mAh cellâŠso youâll see less range than the 3500mAh most likely but its lack of voltage drop might make up for thatâŠif the scooter is really making the NCR18650GAâs drop 0.4V at full throttle (entirely possible) then the Molicels wonât drop anywhere near as much meaning when you get closer to the end of the state of charge youâll be able to run the scooter normally while the NCR18650GAâs will trip the low voltage protection on the BMS the first time a full throttle pull takes the cells down too low.
