I did the same for my XML bike light. The stock set up produces too much throw for a bike light. The wide angle lens is great at spreading the beam out. Here is another example showing the difference between stock light and wide lens modified.
sorry… didn’t even know this site exist… i just found out about this site in late november:)
actually i’ve been using the wide lens adapter since summer… just didn’t use C8 as my bike light…
I just got my C8 a few days ago. And i was VERY dissapointed about this light.
My WF502-b is alot brighter, throws better and everything about it is better.
Is there something wrong with my C8?
Can you check tailcap current with a digital multimeter with thick wire leads? Sounds like it's under-driven. The bigger reflector of the C8 should cause it to throw much better than a P60.
Here's a comparison beamshot I did here showing a KD C8 XM-L at 3A versus a Fake Solarforce L2 (P60) at 3A:
First time using a Multimeter. But i first choosed the 1.2Volt, and i didnt understand why it showed .1v. But i changed it to 12v, and now it works.
And i first tried on my 18650 3400mAh. i got 4.18volts.
Then i putted it in the light, and i measured from the battery and from the “Non-anodized” threads on the flashligt, correct?
i got right above 3volts.
Ok, you need to test for current (DC Amps, set to 10A or 20A setting and move your positive meter lead (if necessary) to the jack used for the 10A / 20A setting (should be marked). Ground lead stays in the same ground jack. Then put the ground lead on the negative end of the battery and touch the positive lead to the flashlight body . Then to change modes you just touch & release one of the leads mimicking pushing a switch on/off. You may find that you need thicker homemade leads to get more realistic readings (you may be able to just bind up and shove an end with bare wire into the meters jack and then use the other end of wire at the flashlight).
1.09 is really low. That's more like a "medium" output level if the measurement is accurate. Are you sure you're using a decent quality meter and good thick leads? See my test with my two meters and different leads on my KD C8. I now only use my Elenco meter with homemade test leads made from 12ga wire and banana plugs from Radio Shack. I get results consistent with other users now.
