Well, at last the Sky Ray xy-600 has finally arrived. I must say
it is a “First Class” light with top shelf machining. No knicks or
dings and clean/lubed theads. I was a little worried about buying
from Manafont, but either I “lucked out” or they have got their act
together. Ordered on 10/31/2012, Arrived by Registered mail
11/15/2012. (not bad, for a China shipment) I specified in my order to test and pack with extra care
and they replyed that they would, and they did. Even included a full
color picture of Godzilla on the box.
The light is perfectly balanced and when you use the switch/handle,
it will make a believer of you. It is 1000% more user friendly than a
tail switch.(IMO) I am now converted and a true believer, in fact I screamed like Jake did to the reverend, that
“Now I see, This is the way ALL lights should be made”.
Reverend Cleophus James: DO YOU SEE THE LIGHT?
Elwood: What light?
Reverend Cleophus James: HAVE YOU SEEEEN THE LIGHT?
Jake: YES! YES! JESUS H. TAP-DANCING CHRIST… I HAVE SEEN THE
LIGHT!!!
Jake & Elwood
I’ll get a good set of bateries from Kuma Bear and post some beam
shots soon. I’m running 4 salvaged cells (Sanyo?) now, but I would
say it is putting out lumens between the range of a TR-J18 and a
beast driver TR-J12. Plenty of light for the nightly dog walk. The
handle is just at the perfect height for lighting the path ahead with
your arm relaxed. It’s like having a pair of car headlights on your
belt.
Only complaint so far is the TOTAL lack of documentation not included with the
light. The following picture shows every bit of english writing you will
receive with the light. (The User Manual, Owners Guide, Parts Doc and
Warranty Card) - It must be tightly packed in code but will not
“unzip”. (LOL)
