So now after the Skyray King ( & Kung) 4-XM-L light was introduced with increased output over the 3-XM-L original SRK, now there is a 6 (six) emitter model…
This one appears to have 3-modes, High, Low and hated strobe.
Should be a hell of a flooder, but less of a thrower than the 3 & 4 emitter models with the smaller reflectors ?
I agree, i already have 3 SRK’s, ( a cool white 3-emitter, warm white 3-emitter, and cool white 4-emitter versions) and they do get hot when run on high for longer periods of time.
im guessing the 6-emitter will double as a camp-stove or space heater.
It probably draws no more current than a stock SRK. I bet it uses the same driver with two LEDs in parallel on each channel. Maybe gives 10% more light than a SRK…
Well, some are driving 3 emitter SRK's at 3 amps per emitter. The emitter is more efficient at 1.5 amps. So maybe less heat at the same overall current. Less throw though do to lower surface brightness, but should be a nice flooder.
I won a 6 emitter bike light on ebay for under $23. It looks like you could just transplant the reflector to a SRK.
That is what I was thinking. Same lumens or close to it, less lux so less throw, but also less heat. Hopefully these start selling for as cheap as the SRK’s do now. When they do I’ll probably pick one up.
my first thought was the same as said above, just six emitters in parallel on the stock driver, so assuming best case scenario, 1a/emitter rather than 2a/emitter, I’d also not tolerate the three modes given and crap pwm, its becoming a bug bear of mine, I dont mind cheap hosts, heck I love cheap hosts, but I want good drivers and emitters in them, which is where I’m aiming with my supfire m6.
My favorite Sky Ray is the mystery light that I modded. Three 18650’s in series, heavy gauge wire with a DRY driver and 3xXM-L2’s de-domed noctigons. Oh and it has a side switch as well that can be wired up. Not as big around as a SRK and just a little longer. It was a ton of work but well worth it. I added heat sinking and now I can run it for a long time on high without it getting hot.
That’s about all I posted. The hardest part was modding the battery carries to series someone around had a tutorial on that. It’s a ton of lumens in a small package, it tears up most other lights that I own. Not the J-19 obviously but for a smaller light it’s very hard to beat.
I think I remember MRsDNF doing a series mod and referencing you and the mystery SRK. I will have to find it and reread it. I have one of those lights. Even though it gets bad mouthed, I like it a lot too. I haven't decided what direction I want to take it. Thanks for the ideas.
dam are they resurrecting the king since there was a thread long live the king!
the kung tried to dethrone or maybe did for some, but the warrior sure did,
but will this king come back to take the crown?
There is only so much light that can be extracted from a beer-can sized light of this design & head size using 4 - 18650s without greating real heating problems, which the SRK 3 and 4 emitter models already have problems with.
Thats one reason why I’m a fan of the big showerhead/plunger lights (going to 15x now). But, more emitters in the same design doesn’t change the current problems SRK already has: burning your hand at 15min for SRK, 5-10min for Kung, not even driven hard, crappy PWM and only 2 light levels.
