SkyRC NC3000 Pro Battery Charger and Analyzer Review
Full review: SkyRC NC3000 Pro Battery Charger and Analyser Review :: Tim McMahon
Specifications
Brand/model SkyRC NC3000 Pro
Modes Charge, Discharge, Cycle, Break-in, MaxBoost, Turbo
Input Power USB-C PD, QC 30W
Charge Protocol QC2.0, QC3.0, PD3.0
Battery Type NiMH, NiCD
Battery Count 4
Battery Sizes AA, AAA
Charge Power Max 22W
Discharge Power Max 15W
Charge Rate 0.2-3A with 0.1A increments
Discharge Rate 0.2-2.5A with 0.1A increments
Trickle Charge 10-300mA or Off
Target Voltage 1.47-1.8V
Discharge Cut-off Voltage 0.5-1.1V
Battery Capacity 100-5000mAh
-ΔV 1-20mV
Working Environment 0°C/32°F ~ 40°C/104°F, 5-75% humidity
Storage Environment -10°C/14°F ~ 70°C/158°F, 5-75% humidity
Weight 380g
Dimension 134*105*61mm
Firmware updatable? Yes (via Bluetooth)
Review date May 2025
Introduction
The SkyRC NC3000 Pro is a USB-C PD/QC powered Battery Charger and Analyser for NiMH/NiCD batteries. It supports AA and AAA battery sizes.
There are six modes available: Charge, Discharge, Cycle, Break-in, MaxBoost and Turbo.
The charger has a colour LCD, a PORT button and a clickable scroll wheel button to control it.
The charger can also be controlled via the SkyCharger app for Android or iOS over Bluetooth.
SkyRC kindly sent this charger for review. I have not been paid for this review nor have I held back my opinions of this charger.
Packaging
The SkyRC NC3000 Pro comes in a relatively compact box with plenty of foam to protect it.
Features and specifications are on the side and on the back of the box.
There is a QR code for the SkyCharger app. The app can be downloaded from the Apple App Store or Google Play.
The following is included in the box:
  • SkyRC NC3000 Pro.
  • Quick start guide.
User Manual
The SkyRC NC3000 Pro has a QR Code for the user manual available under the Settings Menu.
The following URL for the user manual is opened when scanning the QR Code:
https://www.skyrc.com/files/293?open=1
Charger in use
The SkyRC NC3000 Pro is pretty big for a four slot battery charger and analyser that takes AA and AAA batteries.
There is a PORT button and a scroll wheel button to control the SkyRC NC3000 Pro. The quality feels really good.
The positive and negative terminals work well with button top AA and AAA batteries.
The four rubber feet are massive and they feel durable.
There are fans near the USB-C port and there are multiple vent holes to cool everything down.
Dimensions and weight
Dimensions
I took the following measurements using a digital caliper.
Measurement Unit (mm)
Charger height 63.70
Charger width 105.48
Charger length 133.91
Weight
I took the following measurements using a digital scale.
Weight Unit (g)
SkyRC NC3000 Pro 395
Battery compatibility
The SkyRC NC3000 Pro accepts button top AA and AAA NiMH/NiCD batteries.
User interface
See full review.
Testing a battery charger and analyzer
I started by reading HKJ’s web page “How do I test a charger” to figure out how to measure the voltage, current and temperature of a cell in a charger.
I used a 1W 0.1 OHM resistor, copper tape and kapton tape to create a shunt to measure the voltage so that the current could be calculated.
I decided to use parametrek’s ble_meters script to record the data from two Zoyi ZT-300AB Digital Multimeters with Bluetooth connectivity.
After assembling the shunt, I tried to determine the resistance of it so that I could calculate the current:
I measured a resistance of roughly 0.1 Ω using a Fluke 117C Digital Multimeter.
The ble_meters script sees what the Zoyi ZT-300AB has on the display.
For example:
The voltage measured across the shunt might be 0.99mV when there’s a pre-charge current of 100mA.
A 300AB that’s hooked up to the shunt will display 00.99mV and ble_meters will have 0.00099 V.
I can use Ohm’s law (V=IR or I=V/R) to determine the current based on the voltage displayed and the known resistance value of the shunt (0.10173809 Ω).
I = V / R = 0.99mV / 101.73809 mΩ = 0.00099 / 0.10173809 = 0.00973087 A = 9.73 mA
In the interest of transparency and to help others try to measure battery chargers, here is a charger_plot.py script that I created based on bmengineer’s RuTiTe to generate graphs showing the voltage, current and temperature over time.
To measure the temperature, I taped a type K thermocouple to the cell with Kapton tape.
DISCLAIMER: My results may not be very accurate because. A 2A charging current might end up being read as 1.95A or 2.05A. There may also be gaps in the data where Bluetooth connectivity has dropped. I restarted tests where too much data was lost.
Tests
Room temperature: 21 C
I have measured the voltage, current and temperature of various 1.2V Ni-MH, 3.6V Li-ion and 3.2V LiFePO4 cells while charging and discharging them in a the SkyRC NC3000 Pro.
The temperature was measured with a Type K thermocouple.
The voltage was measured with a Zoyi ZT-300AB Digital Multimeter.
The current was calculated by measuring the voltage across a shunt with another Zoyi ZT-300AB Digital Multimeter.
The start and finish voltages were measured with a Fluke 117C.
Battery Type Task Current Cell Link
NiMH Charge 2000mA LADDA AA NiMH 2450mAh Results
NiMH Discharge -2000mA LADDA AA NiMH 2450mAh Results
NiMH Cycle 1250mA LADDA AA NiMH 2450mAh Results
NiMH MaxBoost 1000mA eneloop pro AA NiMH 2450mAh Results
Internal Resistance
The internal resistance detected by the SkyRC NC3000 Pro is very similar measurements by a FNIRSI HRM-10 and a Zoyi ZT-DQ02 LCR Meter.
Battery Type Cell SkyRC NC3000 Pro FNIRSI HRM-10 Zoyi ZT-DQ02
NiMH LADDA AA NiMH 2450mAh 32 mOhm 30.53 mOhm 30.60 mOhm
eneloop eneloop pro AA NiMH 2450mAh 24 mOhm 22.36 mOhm 22.51 mOhm
Thermal Images
I used a Zoyi ZT-R01 IR Thermography Multimeter to take thermal images of the SkyRC NC3000 Pro while using Turbo mode to charge a LADDA AA NiMH 2450mAh cell at a rate of 3A.
Room temperature: 12 C
Time (mm:ss) Max Temperature
00:00 13.5 C
01:00 14.1 C
02:00 14.7 C
03:00 16.1 C
04:00 18.3 C
05:00 19.6 C
06:00 23.9 C
07:00 29.3 C
08:00 30.5 C
Turbo mode finished charging a random LADDA AA NiMH 2450mAh cell after 8 minutes and 20 seconds.
Conclusion
The SkyRC NC3000 Pro Battery Charger and Analyser has become my main AA and AAA charger for 1.2V NiMH batteries.
I really like the user interface and the controls. I prefer the feel of the physical buttons and speed of the scroll wheel compared to capacitive touch screens that can be slow.
It would be even better if I could discharge a battery to 0V. The NC3000 Pro has a 0.5V cut-off.
It is great to see USB-C input being used!
I can highly recommend the SkyRC NC3000 Pro if you are looking for a 1.2V NiMH battery charger and analyser.
Pros:
  • Excellent build quality.
  • Good user interface.
  • Physical buttons and scroll wheel.
  • Colour display.
  • USB-C PD3, QC2 and QC3 input.
  • 3A charging.
  • 2.5A discharging.
  • Fans and vents for cooling.
  • Beep (alarm) that can be adjusted or turned off.
  • SkyCharger app for Android and iOS.
  • Firmware can be upgraded.
Cons:
  • -ΔV is limited to 1mV to 20mV. 0mV would be nice for some situations.
  • Cycle is limited to 3.
Product page
SkyRC NC3000 Pro at skyrc.com
NiMH Charge #1
Firmware: 2.43
Battery Type: NiMH
Mode: Charge
Capacity: 3500mAh
C Current: 1.30A
Target Volt: 1.65V
Cut-off Timer: Off
Restart Volt: Off
-ΔV: 5mV
Trickle Charge: Off
Current Mode: Fixed
Battery: LADDA AA NiMH 2450mAh
Measurement CH1
Start Voltage 1.206
Finish Voltage 1.494
Capacity (mAh) 2498
IR (mOhm) 44
Time (hh:mm:ss) 02:05:04
NiMH Charge #2
Firmware: 2.43
Battery Type: NiMH
Mode: Charge
Capacity: 3500mAh
C Current: 2.00A
Target Volt: 1.65V
Cut-off Timer: Off
Restart Volt: Off
-ΔV: 5mV
Trickle Charge: 50mA
Current Mode: Fixed
Measurement CH1
Start Voltage 1.216
Finish Voltage 1.484
Capacity (mAh) 2490
IR (mOhm) 43
Time (hh:mm:ss) 01:21:03
NiMH Discharge #1
Firmware: 2.43
Battery Type: NiMH
Mode: Discharge
Capacity: Off
D Current: 2.50A
D Cut-off Curr: Off
D Cut-off Volt: 0.90V
Cut-off Timer: Off
Measurement CH1
Start Voltage 1.474
Finish Voltage 1.187
Capacity (mAh) 2487
IR (mOhm) 40
Time (hh:mm:ss) 01:03:15
NiMH Cycle #1
Firmware: 2.43
Mode: Cycle
Capacity: 3500mAh
C.Current: 1.00A
D.Current: 1.00A
Target Volt: 1.65V
D.Cut-off Voltage: 1.00V
Cut-off Timer: Off
Resting After C: 10min
Resting After D: 10min
-ΔV: 5mV
Cycle Mode: C->D
Cycle Count: 3
Current Mode: Fixed
Measurement CH1
Start Voltage 1.192
Finish Voltage 1.181
C1 Capacity (mAh) 2484
D1 Capacity (mAh) 2510
C2 Capacity (mAh) 2484
D2 Capacity (mAh) 2509
C3 Capacity (mAh) 2483
D3 Capacity (mAh) 2509
IR (mOhm) 44
Time (hh:mm:ss) 16:58:05
Internal Resistance and Thermal Images added.
NiMH MaxBoost #1
Firmware: 2.49
Mode: MaxBoost
Capacity: 3500mAh
D.Capacity: 300mAh
C.Current: 1.00A
D.Current: 1.00A
Target Volt: 1.65V
-ΔV: 5mV
Current Mode: Fixed
Battery: eneloop pro AA NiMH 2450mAh
Measurement CH1
Start Voltage 1.299
Finish Voltage 1.370
Capacity (mAh) 300
IR (mOhm) 42
Time (hh:mm:ss) 02:18:11
What’s the purpose of this mode?
MaxBoost
This mode is specifically designed for racing that requires peak performance for the batteries.
It will fully charge the battery, then discharge it to a specified capacity based on your settings.
Before racing, use the Charge mode to fully charge the battery, ensuring optimal performance.
I guess it’s to try to put NiMH cells in a state where they’re 300mAh away from being “full” so that you can top the cells up evenly just before using them.
Here is my review video:
Купил на днях. Пришла с прошивкой v2.43.
Телефон подключил и она сама перепрошилась с моего разрешения на версию v2.56.
need help my skyrc nc3000 when charging show calibrate failed. bluetooth cant connect because bluetooch ic very hot
