Looking at getting a floody handheld flashlight that also has some reasonable throw as well. Also, the light should have a long runtime.
Prefer light that uses just ONE cell. Not sure what cell size, but probably 21700 as a minimum, and maybe up to 26650 size cell?
Prefer light that can use any appropriate sized cell (from above, ie 21700 or 26650 etc) and NOT be restricted to proprietary cells only.
Light MUST have mode memory.
Light MUST be relatively small and can fit in pants pocket.
Light beam angle should be at least about 50°.
Light throw should be at the very least 30 meters.
Runtime at the 30+ meter throw should be at least around 6 hours.
Flashlight price no more than around US $100.
One light I was looking at was the Imalent MS03. But there are a few things that I'm not happy with this light about.
1) Price. The Imalent is just a bit too expensive.
2) Proprietary cell only. This limits what cells can be used in this light. Especially not good in the event the proprietary cell fails and being unable to use more readily available similar sized cells.
3) The runtimes at various throws are a bit too low.
So, the light I'm after should be fairly similar in size and style as the Imalent MS03, but with better throws/runtimes.
EDIT: All lights for consideration MUST have detailed manufacturer specifications to verify data.
Minimum required manufacturer specifications should include - Lumens, Candelas, and runtime. Light throw would be peferable as well but not critical as this can be calculated from Lumens and Candelas.
