What is your purpose and how floody?
Might be worth considering different optic types. Reflector lights (even multi emitter ones) tend to have a spot and spill beam. Larger LEDs normally have a bigger hot spot and brighter spill. And an OP reflector can help blend/merge the hot spot corona into the spill more evenly. This means a small LED (XP-G2/SST-20) can give quite good throw and quite good spill flood at moderate drive levels (assuming a tube style light). A large LED will be brighter, but to get the beam distance you’ll need to drive it harder and probably still not match the lux readings of the smaller LED. So it is a bit of a trade off and balancing act. If you have to drive the LED hard (high amps) to get the beam distance, it means the torch will generally run hot and likely only have shorter runtimes at that beam distance. But up close the beam should be brighter and more even. The smaller LED will normally be able to attain the higher lux without being driven really hard, as it isn’t relying solely on lumen output to attain beam distance.
A shallow reflector will give you a wider spill beam and usually a larger hot spot. While a deeper reflector should give you a more focused hot spot and a smaller diameter spill beam, which should be slightly brighter than a really wide spill beam from the same setup.
Multi emitter setups will use smaller and usually shallower reflectors. So based on the above, you can see they will offer a bigger hot spot and wider spill beam as a rule.
Also take note that the bezel can also impact the diameter of the spill beam, if it is a deep bezel. Shiny bezels (stainless etc) can also sometimes cause rings and other artefacts in the beam.
The other option is to look at TIR optics. These can be single or multi emitter. A TIR is generally smaller than many reflectors or a similar size to a shallow reflector. TIRs also come with different internal dimensions, it is these that will change the focus.
A TIR can have a bright central hotspot. Although generally the spill beam diameter is more narrow. And you’ll often see two distinct spill beams. One quite narrow and bright and a wider duller one. The transition is less smooth than an OP reflector light. The hotspot can also often be quite big with a TIR, even with small emitters. When you have a hot spot, the TIR can still throw quite well, but it is balancing trick and most are not setup for max throw, but a blend of useful characteristics.
Other TIR setups can be setup much more for an even flood. Essentially what you are getting is a “huge” hot spot, that is even and bright. The spill beam is very small and dims rather than a sharp cutoff. I really like this kind of beam for EDC. The beam is not as wide as the spill from a reflector, but because the hot spot is massive by comparison, it means they are nice for walking and lighting up things in front of you for 1 - 3 car lengths. Throw is not their main attribute, although the beam distance can still be quite good, especially at higher lumen outputs.
Multi TIR setups will generally allow more lumens, but often less throw as they are smaller lenses. These can be tailored to have a wide or narrow beam also.
There are some rare zooming TIR lights (Led Lenser/Coast mostly). Which can give some very good beams, although sometimes they can be a bit ringy on full flood, but it does depend on the emitter and lens.
There are other zoomy lights that use aspheric lenses. These can offer really nice flood beams that are completely even with a sharp cutoff at the edges. And zooming in can give you quite good distance in a narrow beam. But you do end up with the LED profile being projected when zoomed.
