I’m a complete newbie in this space - so apologies if this is a daft question. I’m trying to build a powerful flashlight with a diameter of a pen (approx 5-7mm). The LED would be a 3-5W 3mmx3mm. I’m wondering what the smallest MCPCB for this purpose is. I can’t find anything smaller than 10mm. I’m not worried about the heat transfer/dissipation at the moment; I’m just trying to see if there are MCPCB small enough in the first place. Thank you for any advice!
You could always cut / dremel the pcb to make it smaller. However the optic efficiency will be a bigger problem. For such a small frontal opening, it’s hard to get much light out. No space for a reflector. Maybe a small TIR, and definitely not a convex lens as it is the most inefficient way to project light forward.
You could get something custom made, maybe by somewhere like JLPCB? This is likely to be a lower performance aluminium one though, I would agree with FunkyRider and suggest sanding down a larger high performance copper one. It’s pretty easy to do you just have to check for shorts
