[[ UPDATE ]]
I’ve made several updates to the Quick Reference guide. This is release version 1.01
I updated the image below.
Here are the download links to the latest version:
PNG image from Google
- Better quality than the image below which is a compressed JPG
https://tinyurl.com/sofrin-lt1-qr
PDF for printing
- (contains two sizes, The small version can be cut up and inserted inside the battery tube)
https://tinyurl.com/sofirn-qr-pdf
Link to Google Document DRAWING
- Gmail account required to edit.
- to edit, customize or translate Quick Reference
https://tinyurl.com/sofrin-qr-drawing
TEXT only version
▣ Sofirn LT1 Quick Reference ▣
See manual for full instructions
FROM OFF POSITION
[Long-Press]► Turns ON Moon mode - [Press & Hold] to ramp up
[1-Click ]► Turns ON to previously used brightness
[2-Clicks]► Turns ON maximum brightness
[3-Clicks]► Battery check indicated by blinks (i.e.4-blinks, short pause,
1-blink indicates 4.1 volt - “zero” Is indicated with a very quick blink - Exit with [1-Click]
4.2v: 100% charged | 3.7v: 50% charged |3.1v: 10% charged [4-Clicks]► Enable/Disable electronic Lockout- if enabled, only
[Press & Hold] will turn the LEDs ON
[6-Clicks]► Enters Muggle Mode - restricted to ON/OFF & ramping [7-Clicks]► Configures the Switch LED indicator (every [7-clicks]) ycles through OFF/LOW/HIGH/BLINKING modes)
[2-Clicks] [Long-Press]►Enters Blinky and Strobes mode - then [2-Clicks] to cycle through available modes - [1-Click] to exit
FROM ON POSITION
Runtime: 5 hours (brightest) ▣ Charge time: 8-10 hours
[Press&Hold]► Ramps brightness UP/DOWN [1-Click ]► Turns OFF
[2-Clicks]► Maximum brightness-then[2-Clicks] returns to previous
[3-Clicks]► Toggles Smooth/Stepped mode
[6-Clicks]► Exits Muggle Mode
[2-Clicks & Hold]► Enters Tint Mode-ramps from 2,800-5,000K
BLF LT1 Lantern sofirnlight.com
Factory RESET: Loosen battery tube - [Press & Hold] - tighten battery tube then [Hold] for 3 seconds
© 2021 Rob McCormack - Released under: Creative Commons Attribution 4.0 International Public License Sofirn Revision: 10/05/19 - Quick Reference version: 1.01
I wanted to contribute a “Simplified Visual Quick Reference Guide” which concentrates on just the features I use most.
I often found with so much detail in the manual it was difficult to find how to use the basic features.
I would appreciate any feedback on the quick reference guide and any things which are incorrect or not clear.
Quick Reference Guide Features
- it obvious whether the clicking function works from the ON or the OFF position
- I use a little different nomenclature to describe the clicking and holding actions
- it is optimize to display on mobile phones
- I am releasing this under a Creative Commons sharing license
Future Enhancements
- I will make a special size PDF version that can be printed and that can be rolled up and stored inside the battery storage tube.
- this will be a public online Google Document so you can easily customize or translated it (a Gmail account is required)
I hope some may find this useful, it was fun to author this quick reference guide.
Quick Reference on iPhone 8
