Thanks for the information. Let's hope it is not one more 10180 light whose battery is not replaceable, like Lumintop EDC Pico and GlowIMini, and Olight i1R 2
On the other hand, 330lm sounds a bit high for such a small battery, it will be drained in no time.
Having purchased several 10180 tiny lights, I'd rather trade now a bit of compactness for longer runtime. 1/2 AAA (10220) would only add 4mm to the light length, and give a slightly longer runtime.
Looks beautifully machined, and AFAIK the first budget 10180 light with high CRI emitter.
But 50% longer than a DQG Hobi, probably because of the integrated USB charger, also weighs four times as much (26g vs 8g, one of the advertised weight might be wrong, TBC).
No worries, I have a permanent tab open with the “Sofirn new arrivals” that I check every day . This light popped up a few days ago but with not a lot of info on the page (yet).
When OFF, screw down the battery tube to turn on; unscrew the battery tube to turn off.
When On, screw the battery tube more tight to High Mode.
I confirm my feeling it is not a size and weight champion, after comparing it to my DQG Tiny AAA: the latter is only 12mm longer, weights the same including battery (!) and has a much better runtime. Maybe the advertised weight of the new Sofirn SC01 is a typo?
I just received 12 orange C01S from the recent Sofirn deal on Amazon and the knurling is different. The pattern is now wider and the top of the tiny pyramids are much flatter.
The older pattern of knurling was tighter with more peaked contact areas, perfect to give a nice positive functional grip for a small twisty, it’s too smooth now.
I wonder if this change is only on the newer colors or all. I will wait a few days to consider and might have to return these.
Very pleased with my first Sofirn lights: a blue and an orange C01S, Low-High modes as expected, very nice tint. I added a piece of thin frosted film to remove a few artifacts in the beam, which is now perfectly smooth.
I'm considering the following mods:
Adding a magnet (I'll have to order some, found a dealer on AE who sells them by 10 pieces only, I don't need 50 or even worse 10 units). Question to those who have done so: I assume the magnet has to be glued, and therefore cannot be removed later?
Filling the trit slot with resin + GITD powder (I don't want any tritium).
Painting small parts of the lights with high quality GlowInc GITD paint (tail, and edge of the head).
I’ve added magnets to some, a trit vials to one, and tried resin + glow powder with one. The glow powder did nothing for me, can hardly tell it’s there. If trit vials are an option, do them! I love mine with a trit. But if it’s between glow powder and nothing, go for it.
Magnets… At least I needed glue. I put a small drop of super glue gel in the hole and then put the magnet in. To make sure I got it at the right level, I found a piece of horizontal steel (top of my fridge), laid down some foil, and then put my C01S on it, magnet side to the fridge. That sucked the magnet level while the glue cured.
Not sure why it hasn’t been brought up before now but the trit slot is far too deep and too wide. I know we wanted plenty of room but it’s really hard to center and it sits really far down in a pool of UV glue. It’s usable but it would cool if it got refined at some point.
This is not “a little glue on top”, I wouldn’t even mention that. This is “2-3x as much glue as necessary” and a plain waste. Unless you do something like shirnask and fill in the bottom or try to layer the glue it’s way too deep. When you layer it you just create bubbles or make it uneven.
