Specifications
v Emitter: 1*XHP50B, 20* CSP1313(13-3A3-I1-90-B2-BD-GR), 10* Color LEDs(JF-387F-Y)
v Battery Option: 1x 21700 battery
v Working Voltage: 2.7V-4.2V
v Mode Operation: Side e-switch
v Standby Drain: ≤150uA
v Input: Type-A to type-C 5V 3A
v Maximum Charging Current: 3A
v Material: A6061-T6 aluminium alloy
v Water Resistance: IP68 waterproof
v Reflector Type:Orange peel reflector
v Lens Type: Toughened glass lens
v Dimension: 27.5* 30.05* 120.5mm
v Weight: 125g(without a battery)
v Spotlight beam angle: 15°,floodlight beam angle: 85°
v Reverse polarity protection from improper battery installation.
v Low BatteryLevel Warning: When the battery voltage is low, the LED indicator will flash red. Please recharge the battery.ư
Operation Instructions:
ON/OFF:One-click theswitch to turn the light on/off.
DIRECT ACCESS TO TURBO MODE: When the flashlight is on, quickly double-click theswitch to activate Turbo mode.
DIRECT ACCESS TO STROBE MODE:When the flashlight is on Turbo mode, quickly double-click theswitch to enter into Strobe.Then double-click the switch to cycle through Strobe-SOS-Beacon, one-click the switch to return to previous used mode.
MOONLIGHT MODE: When the flashlight is off, press and hold the switch for over one second to access the moonlight mode. CHANGE BRIGHTNESS LEVEL: When the flashlight is on, press and hold the switch and it will, starting from the remembered brightness level, automatically cycle through Low, Medium, and High. The mode is selected when the switch has been released. RAMPING UP/DOWN:When the flashlight is on, hold and press the switch to change brightness steplessly(1lm←→4000lm). Ramping changes its direction when the switch is being pressed again within 1.5 seconds. The LED flashes once when it reaches the lowest or highest end of the ramp.
