I love the “white wall” picture (3 of 4). It’s not easy to create clean beam without concentric circles with a smooth reflector.
I also like the “moon” possibility in the “off” mode like the FW3A has. It is momentary, I hope ?
Love to see more rotary switch lights. Hopefully the tolerance on the ring isn’t too loose otherwise it feels rather tacky. I’m wondering if the tactical mode could be more physically locked out such as lift the ring before rotating it to that direction. I’d hate to accidentally rotate it to tactical mode and strobe. Also wonder if the tactical mode should have fully press to turn on turbo then press and hold for strobe. I’m not sure how often strobe is used and if it’s something to be kept on long term. Half presses can be finicky after all.
This one sounds very nice. I like the rotary switch idea and the UI sounds simple to use. I really like the easy access to moonlight mode. It would be great to get one to try out and review.
I agree with this. Not sure how you would do it, but cycling trough Turbo to get to low IS kind of bad.
Wow, that looks really great! Momentary low and memory sounds good, also great to see an easy to reach lockout. The beam of the SR12 was fantastic, I guess this will be very similar. Does it have a buck driver? Would really like to try this flashlight.
UI looks good. The emitter and body are all nice. If it’s a buck driver then I’m definitely interested.
I’m also interested in the flashlight. This “half-press”, is this half-press and release? or you have to hold half-press all the time?
Regulated version would be awesome.
Is it also possible to put Turbo somewhere else in duty mode, like 2xclicks? Because L-M-H-Turbo cycle is kinda… bad I think.
Thank you for the GAW by the way.
I like the beam profile and the use of a rotary switch, but I’m a bit unsure about the rear switch and the UI. I’d love to give it a go.
Interesting flashlight. I really like the rotary ring, and good choice on the sft25r. I’m in for the contest of early bird tester. Good luck everyone ![]()
Looks like an interesting light. I am always a fan of rotary switches so seeing how that feels would be nice.
I like it. Ive been a big fan of the recent SK and SR lights. Just got the SK40 today.
Thanks for the chance to be an early birds tester, Sofirn!
(I’m not in this one.)
Seems like an interesting light. What price range do you see it being sold at?
I see the light beam that comes out is very clean and neat. Dual mode is very cool, hopefully I win one of them hahaha😅
That looks nice. What does the rotary switch do? Ah, okay, I found it online. It cycles between tactical, lock out and duty mode. That’s nice, no messing around with 6 clicks or some such Masonic hand shake. It would be nice to test this alongside my Manker, Sunwayman and Acebeam lights.
That lock mode is really good, it allows the user to access moonlight with no danger of ever triggering a brighter mode. Nice.
This Tactical Flashlight is very suitable to be paired with the SFT25, the light output produced is also very good. I wonder if I can change modes while the flashlight is on? or does it have to be off?This flashlight is quite interesting, a medium tactical flashlight. Hopefully its durability is also quite good
Good to see SFT25R - 5000K version would be great! - and AR coated lens. UI seems OK on paper, but I would like to know how it works out in practice.
I wonder if Sofirn has considered or tested a TIR optics with this light? Also, it looks like the light has a single tail switch (and the mode ring), but no side switch? May be a good thing, simplifying the UI, but I’m still a sucker for side switches, ‘tactical’ or not.
Looks interesting.
I’m a fan of tactical lights and would enjoy comparing it to my other lights.
So happy to hear you love tactical lights lol
The buck or boost version is next step. For ensure stable operation, we have made a pwm version first. Hope you will enjoy it.
I suppose it cause by UI operation unclear on tactical mode (When half press the button, the light will momentary turbo, if loosen the button the light turn off. When full press the button, the light will momentary strobe, and loosen turn off too.
About the max output for what length of time. I haven’t got the detail data yet.
