Ok everyone, I have finished the batch.
All the orders I have received are packaged up and will ship tomorrow.
What NOT to expect:
Please bear in mind that I dont have a mill. All of the wire holes have to be angled and were drilled by hand. The notches for threading the pill in were also cut by hand. So please understand they are NOT cosmetically perfect.
What you CAN expect:
I put a lot of time in these to ensure the best possible quality in the areas that I think matter most. Number one is threading.
As you can see the threads are very clean and uniform. I have tested each and every single one of these to make sure they thread in like butter and run all the way down. This also ensures a superb thermal path from the sink to the light, which you CAN FEEL!!
With the amps run high ( over 4) you will immediately FEEL the light body get warm and then hot.
The height of the lip on these is taller than a factory pill because it makes it easier to grip in the lathe. They still work with the C8 reflector exactly the same.
Also the surface where the MCPCB sits was fine tuned AFTER all the drilling was done. This will create yet another exceptional thermal junction with proper reflow or epoxy.
FOCUS:
The height where the LED sits is as close to factory as possible. I have tested these with both C8 and T20 lights and in the ones I have they work perfectly.
Conclusion: I have tried very hard to think of everything that could be an issue with wide scale use of these and spend many hours to try to make sure these will work for everyone. However if for ANY reason you are unable to make these work in your personal light please PM me and I will either re-cut, replace or refund if necessary.
I mean it if you are not absolutely 100% thrilled with your product dont hesitate to contact me!
The thread has been marked as SOLD OUT for now because I want to field this batch before I consider another one.
The following orders leave tomorrow. If a BLF handle was not given in the notes buyers will be identified by first name and last initial.
1. Oscar T x 2
2. Troisanh x 2
3. dthrckt x 4
4. Tom E x 2
5. Pulsar x 1 + Mag sink
5. Cateyes x 2
6. Mulie x 2
EDIT:
7. crnkin x 8
If you have paid for product and do not see your name here please contact me.
Thanks again everyone, looking forward to seeing what awesome things you create!
), but not sure if the tarnish may effect electrical conductance or not. Maybe a treatmemt could be applied to protect it? I haven't seen this before in copper I have and ordered - (pipe, heavy wires, copper discs, etc.).
