I’ve been wanting to do this for ages and I’m extremely pleased by how well it turned out.
I have a whole bunch of B&D 18V powertools (drill, sander, saw, strimmer, hedge trimmer, hand vacuum) and although I think the tools are great, I’ve never been very happy with the batteries. The don’t hold their charge very well, weigh a lot, take ages to charge and don’t last very long, especially in the strimmer and hand vacuum. As they all use the same battery, I figured that converting some of them to lithium would fix pretty much all those grumbles.
Also, as some of you know, I’m an enthusiastic battery scavenger and an unrequited skinflint, so I toured the battery recycling bins at work for a few months and (among other things) found 3 macbook pro li-po packs from which I got 5 parallel pairs with an average of 6Ah capacity. Li-po should theoretically deal with high current draw better than the li-ion cells found in laptop batteries, so I went with these as the pilot experiment.
they’re obviously not matched pairs, plus I need some way of monitoring battery charge, so I built the pack with a balance plug wired in using a 5S JST extension from Hobbyking (a few bucks for 10). 12AWG solid copper wire was used for the fly leads and interconnects, also scavenged from work, this time from the machinists recycling bin ![]()
The case was “adjusted” to fit the cells and a port for the female balance plug cut out.
pack wired up and in place
However, as the li-po cells are wider than the nicd cells were tall, the top of the case doesn’t sit flush anymore. So I rummaged around in my pile of scavenged wood (see the theme here?)
cut out a piece the shape of the case
then cut out the spacer using my jigsaw
The case screws are really long, so it all fitted together just fine. The male to male extension was made by soldering together 2 male extension halves and matching the colours of the wires on each half, then wrapped in electricians tape. The voltage monitor is one off eBay for $3 or thereabouts (the most expensive component) and held on with velcro so I can swap it between batteries and even my supercharged mattress inflator (https://budgetlightforum.com/t/-/18754).
installed!
To charge it, I cut off the charging cradle from one of my spare chargers, removed the guts (after I figured out why it didn’t work) and wired it up to a Magicshine female plug I had lying around to that it would plug into one of my charger adapters. Picture was taken before I removed the guts of the cradle, hence the red light ![]()
So how did it work? Freaking awesomely! One of the main spurs in building the pack was that I wanted to clear a section of overgrown trail on a really cool mtb bike route I rode a couple of months ago. The underbrush had grown together over the trail so that riding through it was like getting the skin flayed off your legs. So I figured that I’d strap my hedge trimmer to my camelbak and ride up Tuesday evening (usual ride time, but my buddies were all away) to clear it. Well, after climbing for 50min or so in 30C+/90%+ humidity I finally got to the clogged section and around 3h later I was finished
The pack lasted about 2 1/2h before bank 1 started dropping below 3V, so I switched over to my spare NiCd pack to finish off. Then I packed up, switched my helmet light on and rode back down to the car ![]()
I charged up the pack last night and it took 4.5Ah, so I think that I used most of the capacity. It’ll be interesting to see how it fares with the strimmer, but even if I get 1h out of it, that’s more than enough to do my whole garden. Next up is another pack with li-ion cells, perhaps 5S1P to see if I can make a lighter pack that works with my drill (the li-po pack is about the same weight as the NiCd pack). I’ll also seal up this pack a bit better and paint the wood black or something ![]()
