Sorry if you get bored with my recommendation threads...
Ok, long story short:
My friend at work uses big deal of his time hunting foxes etc.
I recommended him STL-V2 XM-L some time ago, uses 2 x Xtar 2600´s.
However, one of his lights lost driver, I guess. It won´t go on anymore. Clicky is also dead.
We figured out, that clicky + driver + some assembly is almost not worth it for a cheap light. He thinks it could be a better deal to get new one.
I told him, that let´s not buy the same since I really thought it could hold up longer. It did only about 3 months.
So, in need of good 2 x 18650 Thrower.
Most important feats are:
- 2 x 18650 is mandatory for runtime excess of one hour. Battery + charger -gear ready for this setup!
- XM-L is practically mandatory.
- It must be capable of taking some abuse. For example hard shaking -> mode skipping = NO-NO! (running, fast situations)
- It must have a good reach, OP-reflectors are not suitable. STL-V2 does it well enough, is also bright enough.
- MODES: Blinky modes = NO-NO! CAN DO with 1-mode, can do very well on 2-modes. 3-mode WITHOUT Blinkies is acceptable also.
- Side clicky, tail clicky, no difference if it can be used with gloves with ease.
- Price can be a bit over STL-V2´s but not too much.
Bottomline is, he was VERY pleased with the STL-V2. Often referred as the King-of-the-hill flashlight compared to others.
I was not pleased since I always try to get the best price/quality to my buddies so this time, I need your help.
My ideas:
- That Xin TD got already a bit of an approval from my friend. Bad thing is lack of wide user base and lack of longer field test. Good price but does it throw?
- Jetbeam whatwasit again 2-mode but was it with OP reflector??
- SWM T40CS but I´m not sure if it´s too pricy.... Yep, too much...
- Olight M3X is also too pricey...
