Only 26 pcs available for a great price.
Here are several pics to get us acquainted with this interesting compact model from Sunwayman:
More infor here -> http://www.sunwayman.com/fo/pd_153_en.html
…and some specs (from SWM web site):
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours;
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
Turbo (800 lumens, automatically lowers to High after 3 mins continuous use); High (580 lumens, 2 hrs ); Mid (220 lumens, 10 hrs ); Low (27 lumens, 60 hrs );Strobel
● Constant current circuit, constant output
● Uses one single 18650 or two CR123A batteries
● Working voltage: 2.8~8.4V
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern;
● Dimensions: 93mm (length) x 26mm (head diameter) x 24mm (tail diameter)
● Weight: 48.8(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard…
As always, please send me a private message for other relevant info
Rules:
-only members with 30 and more posts, registered before today
-all info only via PM
Thank you
