The V11r should easily crack right open at the fins and ring. I did it with a tight twist of my fingers with little effort. The V10r was locktite shut so needed encouragement to open.
The ring pulls right off then but be careful… the two tiny magnets on the ring fall out easily so can be lost. Do it on a table. The magnets in the V10r never seemed to fall out like on the V11r.
mine supposedly shipped yesterday, from New Jersey, even though the ad says product is in Calif? Tracking says delivery will be next Tuesday? Fedex. Takes a whole week?
Zzzzzzzzzzzzzz.
I ordered last Friday, and the light did not ship until Monday Fedex smartpost. That means the light will get to California, then sit for some time while it goes from Fedex to USPS, then take a day or so to get to you. Mine are scheduled for Monday, I am hoping Saturday as I want to take one with me on a business trip on Monday. We’ll see.
Mine took 4 days to my door. I got in on the first order go round and was the first to receive one.
The second one I ordered oct.12 and should be here tomorrow oct.18. 6 days but I placed the order late friday.
The 3rd one I ordered oct.14 on sunday and looks like it will be here tomorrow also oct.18, 4 days again.
I studied this driver all night last night. Searched every where for some post explaining this driver or some kind of info. Its pretty scattered info.
This driver uses a SD3033 (PAM2803) for the boost IC.
Datasheet SD3033 http://aitendo3.sakura.ne.jp/aitendo_data/product_img/ic/led_driver/SD3303/SD3303.pdf
PAM2803 http://www.s-manuals.com/pdf/datasheet/p/a/pam2803_r2-2_diodes.pdf
Same IC as far as I can tell and The header of my pdf for the SD3033 says “PAM2803”
wight done a lot of work with the PAM2803 in this thread. [WIP] 15mm PAM2803 w/ ATtiny13A rough layout / possibility
I read the entire thread last night still didn’t come up with what I need to know about this V11R driver using a li-ion cell.
I purchased a few better higher value parts from Arrow electronics today to try and mod this thing with what I think might work.
One of the main parts had to be shipped from HK so it maybe a week or 2 before I get to try this.
If anyone has any info to add about this driver, I’d gladly take suggestions from someone who knows this stuff better than me. I’m just self taught threw lots of reading and blowing up stuff. :+1:
Some of the most interest things I found about this IC was in the Application Information in the datasheet about half way down the pdf.
Received two of the three V11R, good quality light, also received two extension tubes I snagged at Lumins, please note the annodization on the extension tube differs slightly from that of the V11R.
For sure, I will be needing a few as well. If you can get them I would get as many as you can. Looks like there will plenty of folks headed your direction for them.
My V11r from a couple of years ago was glued to the point I had to use a couple of channel locks to unscrew the control ring section. If this one is identical with the exception of no glue, then it’s a welcome change considering the need to eventually regrease the ring.
WSitting in the mail this morning . Tint is fair the ar coated lens never help tint .. it also seemed brighter on low then I’d expected . The low seems like it’s a bit over a lumen brighter than I expected.. I thouht these were usually sub lemen lows greay deal on a good light
