From what I understand the rarity of xml2 u3 makes it all but impossible to acquire in some obscure flashlight. The only way afaik for one to know for certain is to have manufactured it.
You can tell xml2 from XML by the color of the substrate around the yellow phosphor. Silver is xml2, green is XML.
Based on some of the results others have posted it seems these contain U2-1A which is still a fantastic emitter. One of these by itself would run you $4-6, the driver another 3-5, the host itself about $10.
This is a good light according to many other posts, at a reasonable price.
I'd guess maybe a XM-L2 U2 1A, maybe a XM-L2 T6 1A for this light's output I and others tested -- and I do agree, still, it's a decent light for the money. I did recommend it to friends, though I'd prefer a more standard C8 host, but their hard to find lately...
502b is 2.55A +/- .2ish on unprotected vs protected 18650.
C8 is 3.55A on 4.14v unprotected NCR18650B 3400 (A little disappointing compared to what others are getting).
C8 has a little bit (maybe 10) tighter spill. The hotspot is roughly 60 tighter. The C8 has 3 separate rings in the beam. Central hotspot, middle ring, and outer spill ring. The tint in the C8 is much more favorable (imo) compared side by side. The 502B has a rather blueish tint.
$4 502B vs $13 C8
C8 wins overall imo, but the 502b has a smaller form factor, is very comfortable to carry, and definitely has its uses.
unknown00101 wrote;
“Got my Tangsfire C8 in today.
C8 is 3.55A on 4.14v unprotected NCR18650B 3400 (A little disappointing compared to what others are getting).”
[/quote]
Solder some braid on the driver spring and that amperage will come up well over 4 amps. Mine has approached 5 amps and some crap started to smoke up off the dome of the LED, Smoking seemed to stop after a short time so I really think it was just some dirt/etc. I have since used a battery with more resistance to lower the power a tad to be safe.
Eventually it will get a Copper Sinkpad and new emitter.
HTH
As somebody said, “Damn you guys are quick!” Thanks for the responses.
Asked about the braiding thinking that no delicate soldering is required, thus even I can do it, my first ever modding. Cursory reading of the linked posts confirms that (even though tad more involved than I first visualized). Will order the braid first and mull over the soldering. Again, thanks for the ‘damn quick’ responses!
dang… that desoldering stuff from radio shack is mad expensive… you can get 2 of those for half price from fasttech.
but then again… you get it right away though
I was surprised to see it has next mode memory. Others here were saying it always should start on high. IMHO, next mode memory is the worst kind of them all.
I checked mine, and thought you performed some sort of bad juju curse upon it because it too was showing next mode memory.
But a few more tests later I found that the reset to high is approximately 8 seconds once turned off (Which is very slow compared to my other lights, normally it is around 2-4 seconds).
That’s great! I checked mine again after seeing your comment, and you are absolutely right. It acts like a next-mode memory when you don’t wait before switching it on again, but turns on high if you wait long enough.
I am really impressed with both the throw and very useful spill.
Mine pull somewhere around 3.2A on protected iirc which is still comparatively low to other’s readings. I believe your leads may be limiting your readings though. I’m using 10gauge a bit over a foot long.
My readings are very similar! $5 meter off E-Bay, but replaced the leads. I am not into the ‘numbers’ but am very happy with this purchase and its’ performance. Hoo-yah!
