Update:
Hi folks,
Just got a tiny light in, it was too cheap to not buy… :person_facepalming: :partying_face:
Looks nice, doesn’t it?
Okay, the picture is edited a little, which is basically misleading, but none the less, it’s a reasonable representation of the actual item.
So it has 3 modes, the obvious high - low - strobe with visible PWM on low.
Mine has NO next mode memory though.
A somewhat greenish tinted fake XP-E, but not too cold.
It came in a cardboard box with padding, 2 spare O-rings and a tiny keychain clasp thingy.
Anyway, it’s a tear down, so here are the parts:
Parts list, from top left to bottom right:
- aluminum switch retaining ring :+1: (no pressed in plastic nightmare)
- decent rubber switch boot
- switch (reverse clicky) it’s crap…[/EDIT]
- decent tail spring
- plastic switch and spring holder
- the battery tube (CR123A or 16340)
- silicone wires (they’re quite thin, but they’re silicone.
- aluminum driver retaining ring :+1:
- 17 mm driver board (but it’s a crappy driver, should be replaced)
- head
- aluminum LED shelf (1mm thick but it’s obviously better than nothing)
- LED on thin (1 mm) 16 mm diameter aluminum board (crappy LED, should be replaced)
- LED / reflector gasket.
- Aluminum OP reflector :+1:
- O-ring
- Glass lens :+1: (not coated)
Stainless steel bezel[EDIT] Newer version have an anodized aluminum bezel…
[/EDIT]
So basically it’s all quite good.
The anodizing looks good too, so does the machining.
I was surprized by the SS bezel and the switch assembly with the black anodized alu retaining ring.
There’s a little too much room between switch boot and switch button so it’s a bit mushy feeling, but nothing that can’t be solved.
I paid less than $ 4 for this little light.
Yes, it has to be modified with a better LED and driver, but that’s the hobby i.m.o.
So i thought i’d share this with you.
(I’ll probably put in a 3x 7135 driver and 4000K 219C with a diffuser behind the lens.)
Thanks for reading. ![]()
