The discharge curves has good tracking.
At 15A the B track stops just after 2.3Ah, this is because my battery holder melts (I hope this is fixed now).
15A is definitly too high current for this cell. The cell temperature is above 75°C (25°C ambient + 50°C temperature raise). Logfile says 87°C for A cell.
On this chart it is obvious how the heat improves the performance at 15A.
Due to the melted battery holder I did only do this for one cell.
Conclusion
The cell looks very good, it has lot of capacity and can handle some current, but I will not recommend it above 10A.
AFAIK the 35E are rated for 8A continuous. I stopped testing at 10A. Driving them to 15A is just battery (and cell holder) torturing - for the sake of science
Thanks very much for the test! I will put these in a power bank, according to the chart they are superior to the GA in all low discharge rates. But they seem to be out of stock everywhere?
I’m 90% sure HKJ has already tested the 30Q, GA, MJ1 and HG2, but in rewrapped versions.
No information found: Imren IMR18650 3000mAh (Yellow) ~ Sanyo INR18650-30Q 3000mAh.
No information found: Efest IMR18650 3000mAh (Purple) ~ LG INR18650-HG2 3000mAh.
Note: The Efest IMR18650 3000mAh (Purple) may or may not be Samsung INR18650-30Q 3000mah.[Reference Mooch] Mooch is the resident battery expert at E-Cigarette Forums, like HKJ is our expert. He says that there are multiple versions of the purple Efest cell. The three-pronged positive terminal version is probably a 30Q. He hasn’t tested the 4-pronged version. The picture of the one HKJ tested shows 4 prongs. So, my interpretation of this is that “maybe it is, maybe it isn’t” a 30Q.
Yes and No: Imren IMR18650 3500mAh (Green) = LG MJ1 18650 3500mAh. [Reference Mooch] Note: Mooch states that there are two versions of the Imren battery. One is a Panasonic NCR18650GA 3300mAh, the other is an LG MJ1 3500mAh.
Unless there is further documentation, I’d suggest that HKJ has not already tested the 30Q or HG2 batteries in any form.
I often look for your charts here and on CPF but sometimes I can’t find a specific one that I’ve seen before, I think you could make index thread with all your reviewed batteries and put the link in your signature, that would be really helpful!
I hope you weren’t responding to me. I merely attempted to confirm what HKJ said (or implied) about the Sanyo NCR18650GA, Sanyo INR18650-30Q, LG INR18650-HG2, and the LG MJ1 18650 batteries. I was not looking for what other people’s tests had found regarding these batteries.
If you were responding to Bugsy’s post #7, I found your tests of the GA, 30Q, and MJ1, as follows:
