testing two of KD's new Nichia 219b leds (4500K'92CRI' and 5500K)
Reflowing is easier then it may seem. Just try on a cheap led.
BUMP.
thanks.
I already tried, guess I’m going to need a better soldering iron (mine is a cheap crap, I already planned to buy a new one but can’t found something that screams “quality” locally, haven’t really looked on the Internet for now I admit), because I failed miserably.
I wanted to try in the oven too, but my wife totally disagree on this one :bigsmile:
I see, well, it is difficult with Nichia, the 219B comes in various tints and CRI. But if Cree's coding system is complicated, Nichia is even worse. I could not find any documention that directly couples the exact specifications of a particular led to a order code. It does not help that Kaidomain is sloppy with their descriptions of codes either.
I love Osram and Philips for their clear and to-the-point documentation.
thanks.
I think the 5000k Luxeon ‘daylight’ tint that Zebralight currently offer in a few models has been stated to be close to a ‘pure white’ tint. Remember also that there is no such thing as ‘pure white’, our eyes adjust massively to varying colour temperatures in the environment and what may look rosy tinted against a white wall with cloudy daylight coming through the window may look green tinted on the same wall when the room is light by incandescent.
The proportion of R/G sensitive cones in the retina can vary between individuals too, I posted this in another thread a while back:
So there is likely a lot of individual variance as well, whilst to some 4000k might look like ‘pure white’, to others 6000k might look like ‘pure white’ in similar conditions. You have to find your own general preference and look for that, mine is generally around 5000k i.e 3D/4A.
Btw, as that old link is now dead, here’s one that works if you want to read the paper: http://aria.cvs.rochester.edu/papers/Roorda99nature.pdf
If you plan to do many reflows in the future (of course you do!) it is worth the trouble to build a set-up for it. If you search BLF for 'reflow' there's many nice ways to do it.
I really like my way, a rebuilt 12V solder iron with a aluminium block mounted on it, it took some effort but I am still really glad I made it. I described it here some time ago (please do not watch the video , I am very handy with reflows nowadays). It is compact and easy to work with, and after some experimenting with the best voltage, it can be set to a constant temperature not too far above the solder melting point, to minimize led damage.
Thank you, I’ll try to build something like that :slight_smile:
I’m one of the lucky man who had got 5 pcs of 219B from IS a few weeks ago. Then I made a triple 219B on Donn’s solid copper heatsink together with DrJones’s lucidrv driver. The result was impressive… (I do not have 219B from KD to compare)
The triple 219B is considerably brighter than triple 219A (same set up). The B render BLUE and WHITE better than the A. On the other hand, The A render RED and YELLOW better than the B.
Sorry for my crap photo. Both Nichia make the triple XPG2 R5 3C on the left looks yellow. Triple 219B is in the middle. Right hand side is our familiar pinky 219A which is still my favourite.
Thanks a lot Syracuse, that is very useful information. Actually your observations on the 219b high cri from IS match quite well with what I found from the 219b high cri from Kaidomain. It let me suspect that KD was not selling the high cri 219b. So now every scenario is open:
1)KD is right, and so is IS, and I did not recognise the 92cri because I like warm tints too much.
2)KD is wrong (not 92cri) and IS is right (different tint than 219a but still 92cri), but also
3)both are wrong, and IS suspected that and withdrew their version of 219b.
4) IS is wrong and KD is right? That would be the world upside down , and nothing supports that
("exactly, my dear Watson" )
At first, I also doubt about the 92cri. But this 219b renders colour much better than the XP-G2 R5 3C. 0:)
I do believe in IS, and I think they use this emitter in their FOURSEVENS Preon P2 High CRI Edition Neutral White.
I.S. just ran out, they got a limited quantity for the special run of the P2 and had some left over, that's all. I'm sure when they're able to get more they'll be listed again.
syracuse, thanks for the info a beamshots!
I overlapped Nichia tint bin with Cree tint, hopefully it is helpful.
Cool. Thanks THE_dAY.
+1
Thanks for the video of your setup djozz. I dont recall seeing it before. Looks like I need a set of bent nose tweezers. Do they come in teflon (non stick).
These two tweezers were my work tweezers for nine years in my lab-days, Dumont antistatic, perfect tweezers but way too expensive for hobby-purposes. I was given them when I left the job :-)
Was there a final verdict on the 219B from KD? Are they legit 92CRI emitters?
They’re also selling 219A B11 SW45 92CRI emitters. Any idea if those are legit?
i was looking at getting a solarforce p60 219B drop in from Vinh in the US, but he “thinks” it’s 92+HCRI.
not so sure now.
the only 219B CRI i trust is that of HDS Systems. 85+, MBI’s HF’s 219A, and darksucks new beta QR 219A to be the real stuff.
thanks.
I purchased some of the 92cri emitters back when they first came out, but I just now finally put one in a light. I really like it a lot. I don't think I'm a reliable judge of tint and cri. To my eyes, it really seems to have a very high cri. Actually seems slightly higher than the older high cri 219. The tint is much whiter, but doesn't feel cold.
I'm a fan of this new emitter.
