Ok, first off I am putting them here and not in the commercial seller spot mostly because these are left overs and I will NOT be making any more of these. I am not even making minimum wage off the work in these.
So get them while you can!
Second some of these are “prototype” models with various levels of nicks and scratches (none effecting performance and most not very noticeable all not worth selling on ebay with their stupid rules and even worse buyers), about half of them from the factory and the other half the custom modding for the shelf.
Ok, I am listing these for sale here even though I know they are a bit more then most BLF’ers like to spend because I need to free up some funds ASAP for some other projects (gonna start making small batches of Texas Avenger drivers and going to be running a group buy for some 90+ CRI 219C LED’s, both of which need seed money that I do not have at the moment).
So here I have the ultimate Texas Ace 8x Skyray kings
with custom hand made 1/2” thick solid shelves
FET+1 V2 driver with temp sensor and copper contact plate for lower resistance and better heat sinking
Nice silicone wires
Screwed down MCPCB / reflector for max heat transfer.
20-26+ amps on high drain cells.
just under 4000 lumens at turn on the stock latticebright LED’s
Or I can upgrade one of them to 8000 lumens with XM-L2 U2 3D’s, I only have enough LED’s for one though.
The stock latticebright LED’s without spring bypasses actually work well, the tint is cool but not any worse then any other cool white light. The throw is actually impressive and MUCH better then with XM-L2’s. The XM-L2 version is the best flooder I own by far but the latticebright versions are a great general use light.
These make great hosts for extreme builds. My 8000 lumen version is my go to light for anything within 100m as it lights up EVERYTHING in that range. I also have plans to build an XHP50 version of one of these for 20k+ lumens.
These are easily the most extreme heat sinked Skyray king you can get.
So now for the actual lights, here are some random shots of various lights., I will list what I have left for sale in the next post.
