Please add:
Trustfire 3000 mAh "Flames" - 2494 mAh @ 1A, down to 3.0V; 2445 mAh @ 2.8A, down to 3.0V
All data courtesy of Joerch.
Please add:
Why are the first 25 or so links (in the "Battery" column) towards the top of the list of the battery pointing to budgetlightforum.cz.cc ???
Because that was before going .com [ budgetlightforum ] + 4 more weeks of school [ something like that ] to complete my Cert 4 in IT
But thanks for mentioning it , I will fix it as time permits ..
Reminder to self - fix links in DB !
Yeah, I thought I had a virus LoL. Every time I clicked on a link I was getting redirected to some random stupid ad site. After doing a full scan twice, I went back and realized half the URLs were just different.
hi, i use a cheap charger (ultrafire wf-188) and cant measure voltages, sorry. but i've got a high quality digital sliding caliper so here are my length measurements:
XTAR 18700 2600mAh (average size: L x D: 69.7 x 18.5 mm)
cell1 L x D: 69.59 x 18.48 mm
cell2 L x D: 69.67 x 18.43 mm
and finally the capacities:
Discharge test runs in genuine Imax B6 at -0.2A discharge rate from 4.200+V (UT61E) down to the B6-standard "3.00V" termination limit:
test run #1 (tested: cell#1): 2501mAh, remaining resting voltage 3.281V recovered after 2 hours
test run #2 (tested: cell#2): 2515mAh, remaining resting voltage 3.390V recovered after 2 hours
Notes:
TrustFire 14500 900mAh (average size: L x D: 51.1 x 14.0 mm)
cell1 L x D: 51.13 x 13.98 mm
cell2 L x D: 50.98 x 14.01 mm
(in comparison, cheap AA Alkaline are 50.3 x 14.0 mm; this means that the flamed Protected TrustFire 14500's are 0.8mm longer than standard AA Alkaline.)
Trustfire Flames mAh test
Discharged to 3 volt and charged @ 0.5 amp
Cell A
Cell B
End voltage is a bit low on the last as its sat on the charger all day waiting for me to come home from work befor the last picture was taken.
......Battery.......
.Claimed.Capacity.
.Discharge.Results.
.Cell.Dimensions.
.Protected.
........Charger........
.....Cell.Type........
1100mAh
411/415mAh @ 0.5A
366/372mAh @ 1.0A
L-49.3/49.7mm
D-14.3mm
No
Maha C9000
Button Top
(difference in lengths between the two cells is due to different heights of the button top)
Cell A Discharged to 3 volt and then i recharged at 0.5 amp
Cell B Discharged to 3 volt and then i recharged at 0.5 amp
More infomation here
Lidl special AA LSD. Discharged on an Angeleyes charger - I don't own a C9000.
Nominally 2100mAh. First full cycle. Noticed that they got alarmingly hot at a 528mA discharge which is not a good sign. Also I doubt their LSDness - they certainly aren't up to the standards of the GP Recycos I have or the Eneloops. Still too hot to comfortably touch after around 1750mAh discharge.
Cell | Capacity mAh |
1 | 1870 |
2 | 2056 |
3 | 2011 |
4 | 1856 |
Just as well they were cheap because they don't look very good. I'll rest them and recharge them then test one at a time for a few weeks to see how they hold their charge. From the heat from them on a 500mA discharge (Eneloops will do 8 amps) I doubt they'd be good in a high-drain application.
i own " BTY Ni-MH 1000, Rechargeable AAA 1.2V " and it says " Charge Methods: Standard Charge: 15hrs at 100mA, Quick Charge: 4.5hrs at 300mA ".
They're in my house phone and all i can say is: my brand name (VARTA) AAA 1.2V rechargeables last 4 times as long as the BTY. And they also get quite warm (in the house phone or in flashlights). Not recommended.
i bought them thru ebay.
BTY cells are junk which is best avoided.
Lidl Tronic cells are little better.
Cell 1
2019mAh
Cell2
1625mAh
Cell 3
1852mAh
Cell 4
2027mAh
Not very good at all.
1 | 1870 |
2 | 2056 |
3 | 2011 |
4 | 1856 |
More info here
Trustfire "New Flames" 3000mAh 18650 protected.
11,70 $ / pair.
From Manafont. Link: http://www.manafont.com/product_info.php/protected-trustfire-18650-37v-3000mah-rechargeable-batteries-2pcsset-p-7941
L = 68,7mm
W = 18,5mm
1st cycle.
From 4,16V down to 2,70V with 1A.
Discharger used: iMax B6
Cell 1 : 2502mAh
Cell 2 : 2496mAh
Bought from eBay, possibly not precisely from this dealer but he said "they were the cheapest ones" so might be a close guess.
(acquired from friend, gave better ones for replacement)
1,90$ / piece.
L = 68,9mm
W = 18,3mm
Note: as long as protected´s or even longer, yet un-protected. (will be gutted later...)
??? cycle.
From 4,22V down to 2,70V with 1A.
Cell 1 : 697mAh
Am I the winner in drag racing an 18650 from 4,20V -> 2,70V in least possible mAh´s? :D
edit:
interior ripped open. Notice the plastic "filler tube"
Just for reference:
A pair of Trustfire Flame 14500 (protected) from manafont
Discharged these at wrong amperage, used 1A instead of 0,5A that was suggested.
1st cycle
Cell 1 : 757mAh
Cell 2 : 662mAh
Seems like I got a bad pair...
I got some batteries from DD , just to see what there selling .. Dek 800 and Sunos 900 ...
Initial discharge = From packet [ 500mAh discharge ]
Dek 1- 351mAh / 2- 386mAh
Sunos 1- 375mAh / 2- 315mAh
After being fully charged , discharged @ 500mAh
Dek 1- 643mAh / 2- 626mAh
Sunos 1- 712mAh / 2- 731mAh
Heard some good things about Turnigy AA LSD batteries , so thought I might buy some ..
Also new DEK2750 [ though it does not come close to claimed capacity ]
Discharging @ 1A returned :
DEK - 1897mAh - 1916mAh [ 2750 claimed capacity ]
Turnigy - 2196mAh - 2163mAh [ Claimed capacity 2200mAh ]
Discharge test with 4 different flashlights ...
Turnigy - 1.75A - 2A - 1.99A - 2.1A
DEK - 1.7A - 1.89A - 1.9A - 2A
Rayovac - 1.75A - 2A - 1.9A - 2A
AccuEvolution - 1.85A - 1.9A - 2A - 2.22A
The DEK from DinoDirect were some what disappointing [ capacity claim ] , on the other hand the Turnigy LSD AA's performed very well , and I would be seriously tempted to buy some more , if your interested in the Turnigy , head on over to HobbyKing ...
......................... | ......Battery....... | .Claimed.Capacity. | .Discharge.Results. | .Cell.Dimensions. | .Protected. | ........Charger........ | .....Cell.Type........ |
EagleTac 18650 |
3100mAh | 2867mAh @ 1.0A - 2.6V termination | L-68.1mm D-18.1mm |
Yes | Imax B6 | Button Top |
