Lidl special AA LSD. Discharged on an Angeleyes charger - I don't own a C9000.
Nominally 2100mAh. First full cycle. Noticed that they got alarmingly hot at a 528mA discharge which is not a good sign. Also I doubt their LSDness - they certainly aren't up to the standards of the GP Recycos I have or the Eneloops. Still too hot to comfortably touch after around 1750mAh discharge.
Cell
Capacity
mAh
1
1870
2
2056
3
2011
4
1856
Just as well they were cheap because they don't look very good. I'll rest them and recharge them then test one at a time for a few weeks to see how they hold their charge. From the heat from them on a 500mA discharge (Eneloops will do 8 amps) I doubt they'd be good in a high-drain application.
They're in my house phone and all i can say is: my brand name (VARTA) AAA 1.2V rechargeables last 4 times as long as the BTY. And they also get quite warm (in the house phone or in flashlights). Not recommended.
The DEK from DinoDirect were some what disappointing [ capacity claim ] , on the other hand the Turnigy LSD AA's performed very well , and I would be seriously tempted to buy some more , if your interested in the Turnigy , head on over to HobbyKing ...
I got some Turnigy 2200 mAh LSD AA batteries from Hobby King this week. I discharged them right out of the package at 500mA. Then I did a Refresh/Analyze cycle at 1000 charge and 1000 discharge on my Maha C9000. Very good results:
Cell
Initial Discharge
1000mA Discharge from Full
1
1667
2411
2
1654
2318
3
1644
2299
4
1645
2385
5
1631
2344
6
1642
2343
7
1683
2368
8
1650
2333
Avg.
1652
2350
Very consistent results. Eneloops and Duraloops usually come in just under 2000. What is impressive about this is that if these batteries can maintain 75% of their charge after a year (1763 mAh), they would have more capacity than Eneloops which retain 85% of their charge (1700 mAh). I plan on discharging 2 cells each at 1 month, 3 months, 6 months, and 1 year. Continued here.
On receipt, the first cell of the pair measured 3.32 volts; initial discharge got a whopping ONE mAh. The second cell measured 3.35 volts and also registered 1 mAh, but was not tested because it became warm even at an 0.2 amp charge rate (at 1 A after the initial discharge, voltage shot up to 4.2 after only 60 mAh and then dropped back under 4 volts!).
