No sorry, I’m not going to do that.
ok
RD6030 60V 30A DC to DC power supply feedback
This is my third purchase of this converter. my first device is 18 amps and I am very pleased. Very good purchase. You can take a look, for the suitable PSU I still need to wait. I recommend
Could someone explain to a layman exactly what this item does? I stumbled across this thread, and now I’m curious what people would use this for. Thanks.
Lab power supply. I used it here to measure a Wurkkos HD10 without battery to see how it behaves with stable and regulated input voltage. So I could measure brightness at various simulated battery voltage levels.
Since lab PSUs are constant current capable too you can use them to directly drive LEDs for testing, without any LED drivers, or supply other electronic things etc.
this is a power supply, you can search it on youtube , you will see how to use
also you can charge the battery, provide any voltage that you need
It is an adjustable power supply. I use it for my LED-Tests. I have the RD6024 for these, which is very similar to this RD6030 shown here.
thank you , it is good device
RD6030 60V 30A power supply feedback
item received and it looks same as what the picture shows, good quality, fast shipping
very good, I use it to replace my old power supply, and the output cable is soft and low resistance
the output is accurate, and there is no over-shoot on the output, easy to use
X25A 25A Banana Plug to Alligator Clip Test Cable used for RD6024 feedback
good material, much better than what I made, recommended
RK6006-C 60V 6A AC to DC power supply feedback
it is really small and the output is accurate, good, will consider to order another one if necessary
Aliexpress: RK6006-C 60V 6a 4-stellig AC zu DC einstellbare digitale Steuerung stabilisierte Labor bank Strom versorgung Batterie Lade einfache Bedienung
compact power supply, simple operation panel, temperature control fan, and output is accurate
RD6012P 60V 12A 5 digit power supply feedback
nice item, high accuracy, I can use it to charge battery or repair something, good quality and low price, recommend
Aliexpress: Rd rd6012p 5-stellige USB-Gleichstrom-Laptop-Handy-Reparatur bank reguliertes Labor-Netzteil einstellbar 60V 12a 720W
RD6030 input voltage protection, 7-70V DC normal range, 72V DC warning, 100V DC turn off
RD6030 Aliexpress link: Rd rd6030 rd6030w 60v 30a DC einstellbare Abwärts spannung Bank geregelte Strom versorgung Buck Converter Batterie ladung & 1500W Netzteil - AliExpress 1420
RK6006 60V 6A power supply feedback
I make the case by myself and use it to charge e-bike battery, good device
aliexpress: Rd rk6006 60V 6a 4-stellige Kommunikation einstellbar Gleichstrom-zu-Gleichstrom-Abwärts spannungs-Bank-Netzteil-Buck-Wandler
RD6012P 60V 12A 5-digit power supply feedback
I bought it because my friend recommend it to me, easy to use, and there are many battery in my shop need to be charged
Aliexpress: RD RD6012P 5 digit USB DC DC Laptop Mobile Phone Repair Bench Regulated Lab Power Supply Adjustable 60V 12A 720W
RK6006 power supply is also user friendly, you can enable/disable the button tune, and you can adjust the screen brightness according to your environment brightness.
aliexpress: https://www.aliexpress.us/item/3256805243272337.html
https://youtube.com/shorts/lLZRugosY3Y
