@RD_tech is there an official description of RS-485 MODBUS-RTU registers and the communication protocol used to control the power supply? Which FW version is needed to use the RS-485 module? I bought this module for my RD6024.
thank you very much for your message
for now RS485 board, we only allow to follow our instruction
5. RS485 User instuction(section 4.3.4):
https://drive.google.com/drive/folders/1-Hks1Yg1X0fL7mmZzzlSUfhrV2KkYGy2?usp=sharing
I need the description of communication protocol, I cannot use the software you provide.
I found a reverse engineered protocol description. I don’t understand why there is no official document where the Modbus protocol is properly described, especially since such a module is sold on Aliexpress.
I am so sorry for that . we don’t provide commnication protocol
Ok. Weird decision to say the least. Thank you for the response.
because our RD series all function was not finished, so we don’t provide it now
RK6006 customs display color, you can set the display with the color you need, do not forget to turn on the enable option
aliexpress: https://www.aliexpress.us/item/3256805243272337.html
RK6006 power limit function, voltage priority mode, when the output reaches the limited power, the current will be decreased when you keep increasing output voltage
battery charging function of RD series power supply, use the green battery charging terminal, it has protection method, even you connect wrong terminal, it will not charge
RD6030: RD RD6030 RD6030W 60V 30A DC Adjustable Step Down Voltage Bench Regulated Power Supply Buck Converter Battery Charging&1500W PSU - AliExpress 1420
if you want to see more about the product, just contact us
Aging test, all the power supplies in our shop pass the aging test, before outbound the warehouse, they need to do aging test 3 times, so that normally there is no problem when you receive them, if you have needs to see other aspects, please tell us
Custom RK6006 Logo, you can upload 240*240 picture as logo, if you do not need logo, you can also disable boot logo at setting page
program output of RK6006, you can use PC software to set the output voltage and current for certain time
aliexpress: Rd rk6006 60V 6a 4-stellige Kommunikation einstellbar Gleichstrom-zu-Gleichstrom-Abwärts spannungs-Bank-Netzteil-Buck-Wandler
compact design, compare the size of RD6006P(RD series has same size) and RK6006, you will find RK6006 is really small, if you only need such voltage and current, you can choose RK6006, if you need more user friendly, you can choose RD series power supply
RD6030 power limit function, voltage priority mode, when the output reaches the limited power, the current will be decreased when you keep increasing output voltage, other RD series devices also have this function
choose good quality connection cables for power supply, when short the output with cable, you can see the voltage drop on the output cable, the lower the voltage, the better the quality
Notice for inductive load like motor, please limit the output in 1/3 range, for example RD6012 12A output, limit it in 4A range, RD6030 in 10A range to protect the power supply
Extra backup fuse available, there is a backup fuse in the RD power supply box, only when you burn the fuse by wrong operation, you can use it to replace the burned fuse, normally you do not need it, just keep it
RD power supply battery reverse protection, when using battery charging terminal,if you connect battery in the wrong way, it will not charge battery even you turn on the output
Auto output when power on, if you always power on same load with same voltage and current, you can choose to set auto output when power on,turn on “BOOT POWER” option and it is OK
RK6006 60V 6A power supply feedback
Well packed and also a very helpful and communicative seller. I highly recommend this seller.
