Wingman:
16,5mm reflector hole
I ordered my M4B with a 16.5mm hole reflector and it did not come with a LED gasket.
I needed to order it separately for 1yaun via this item and adding a note saying 16.5mm gasket:
Edit(4/7/26):
All gaskets are listed now:
https://e.tb.cn/h.iNXm1CyLkOY5gih?tk=7b4N5VdGYNb
Sirstinky
(Sirstinky)
March 31, 2026, 7:07pm
22
That link…i don’t speak Chinese
You can copy&paste TaoBao links into Superbuy and it will convert it to English(everything but pictures).
Let’s see if I can share a Superbuy Link .
It should come up like this(once you’re logged in and set the language to English):
This is the Superbuy link that interests me…
(The D2GC)
https://www.superbuy.com/en/page/buy/?nTag=Home-search&from=search-input&url=https%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fid%3D750345596036
Looks like it’s just a host, but it’s approximate the right size for me (45mm head and it accepts a 21700 cell).
billy_s
(DayDreamers)
April 4, 2026, 3:43am
25
elemental:
drivers
Should’ve included driver info in the first post! Thanks for the input
PNWest
April 4, 2026, 4:04am
26
Are there switches available for these? I’ve put together 3 and was able to put together some custom switches with a pcb that @INeedMoreLumens put together. It would nice if there were some ready to go.
billy_s
(DayDreamers)
April 4, 2026, 5:37am
27
For the tail switch model there’s one installed in the tail cap. For the side switch model it comes with the driver.
PNWest
April 4, 2026, 1:23pm
28
I did not know the switch came with the driver. I’ve only ordered the host and only side switch models.
billy_s
(DayDreamers)
April 4, 2026, 1:31pm
29
Which host have you ordered?
PNWest
April 4, 2026, 1:39pm
30
Ive built two D2GC and one M4B.
I had the switch pcb built by OSH and ordered the switches from digikey.
billy_s
(DayDreamers)
April 4, 2026, 1:57pm
31
Did you also built your own driver?
PNWest
April 4, 2026, 3:11pm
32
No that is way beyond my capabilities. I’ve used Hank/Anduril drivers from Jackson.
Specifically you used a 22mm D4v2 Lume X1 driver for the D2GC and a 31mm D4Sv2 driver for the M4B and a 11.9mm switch PCB.
PNWest
April 4, 2026, 3:48pm
34
You are correct. Thanks. I can’t remember without looking at my notes which aren’t with me right now.
geforce73
(geforce73)
April 4, 2026, 4:21pm
35
Do you have the wiring diagram for the red driver? How do I solder the fans and LED leads onto the driver?
elemental
(elemental)
April 4, 2026, 4:33pm
36
For LED wires you solder the red directly to the giant button in spring assembly, and for the black wires to the two empty terminals right next to it. No idea where for the fan.
geforce73:
wiring diagram
geforce73:
fans
The F8A I’ve seen built with that driver have a separate thermostat that controls the fans.
geforce73
(geforce73)
April 4, 2026, 5:32pm
38
I am going to ask the Taobao seller for more information.
billy_s
(DayDreamers)
April 5, 2026, 3:23am
39
There’s no integrated fan controller on “flying” 47mm driver.
geforce73
(geforce73)
April 5, 2026, 3:29am
40
Thanks. How can I add a fan controller for the F8A mod?
