Hey guys!
Tonight Ive been playing around with my L2i and XML drop in. It uses a max 2A, that many KD C8`s are supplied with.
Ive always wanted to know how (not)well triple A batteries handle a "hungry" XML.
Im actually pretty positive about the results.
I used to have a Low-Voltage XPG R5 in this L2i light.
Here are some findings:
R5 low voltage drop in | XML 2A max drop in |
High: 0.98A |
High: 1.05A |
Medium: 0.43A | Medium:0.48A |
Low: 0.08 | Low: 0.05A |
These measurements are taken directly after turning on the light.
Note that the batteries had some use, so they were not 100% full.
The interesting thing about the XML is the low Low. Which should give a nice long runtime.
Now I inserted the XML with the 3 triple A`s, and see how run-time is on High.
1 min | 1.05A |
15min | 1.12A (strange?) |
25min | 0.87A |
35min | 0.23A |
43min | turned to low mode with 0.02A |
After about 32 minutes the light started to lower the output significantly.
at 43 minutes i thought the light turned off, but it went to a low low, which gave about 5-10 lumens for another hour.
Then it turned completely off.
The Voltage of the 3xAAA was at that point 2.7V
Cells where about 0.9 each.
Some questions I have now.
1st, do you think the driver has a LV shut off?
Which means, that I can use it with unprotected 18650 cells. Even I know that 2.7V is pretty low for the cells, but at least its safer than no protection, right?
2nd, it looks like the XML is a bit nicer for the triple A batteries, because it doesnt drain them all the way to 0V.
Is that a correct observation? Because the XPG R5 low voltage can go down to 0.8V.. which will be about 0.3V per cell, which I think is not to great for AAA batteries.
Here some crappy comparison shots between the R5 on 3xAAA and the XML on 3xAAA
Mouseover is with the XML.
R5 is the one where you can see the white cushion on the left.
This is not the place to look for nice white wall beamshots to compare tints, colors etc.. Just raw Output! ;)
so the conclusion is: Im pretty happy with the results, even for 3xAAA.
If someone is thinking about getting a useful triple A light, consider a Mild driven XML!
More output on High..
And a good long runtime on low. 0.05A
