Hello,
I am considering buying an HP30R v2 and I wanted to know if anybody had any thoughts or comments about it.
I want it because it seems to be the highest capacity headlamp available and is also no slouch for brightness.
I have an Armytek Wizard Pro Nichia, but I tend to use my lights as worklights and often find myself having to interrupt what I am doing to go swap batteries.
I found this review which seems pretty helpful:
https://budgetlightforum.com/t/fenix-hp30r-v2-review-runtime-beamshots-2-21700-xhp50-2-2-xp-g2/70173
It looks like it comes with a set of protected batteries but will it work with regular unprotected cells? Based on the pictures in the review it looks like it does require button-tops, but would an unprotected flat-top be long enough with just a little magnet? I got âJoeâs Surprise Samplerâ from K&J Magnetics and it came with some magnets that are about the right size.
I assume the TM-30 and CRI numbers are nothing to write home about because Fenix indeed doesnât seem to have written about them.
It only seems to be rated IP66. I would like to see IP67 or 68, but it probably wouldnât matter for me anyway.
It seems to have the 2 cells in series. Does it charge them in series too? Does it have built in balancing? I guess that is why it comes with protected batteries.
It sounds like it has slow charging, I donât even know if I have a separate charger that will fit protected 21700s.
It seems to have a nice interface, just a knob and a button.
The battery gauge on the battery box looks like it would be nice.
It has a USB A and C port. USB C works for input, but does it also work for output?
4500K on the flood channel is fine, I donât think I have a problem with 5700k on the throw channel.
I canât think of anything else right now. It is the only 2x 21700 headlamp I know of and that Parametrek had.
It seems appropriate for BLF because at $200 from B&H Photo Video, it will make my budget light forâum.
