At the moment they are open for suggestions but keep in mind a brand new from the ground up design and construction will be expensive if they are only going to sell 50-100+ flashlights on here. BLF people will generally want a budget flashlight but its not totally out of the question.
Minor modifications to existing flashlights will be possible within reason as well.
This is more or less asking what you want as they don’t have anything in mind yet. If more people tend to agree on the same things then its pretty likely that is what the BFL edition will be if it has enough interest.
Sounds interesting but I guess it will be to expensive for many purchases. Not like the mini 01 or the A8 which were a steal for what they are.
But all depends what deal you can work out.
My A8 is the biggest light I will likely buy, though I make bigger ones, so I’d vote for a small model. 18650, 2x rcr123, or smaller 14500. Not really interested in any alkaleak models.
Go big! TN31 XML2 Run at 4.5 Amps on highest level, flawless reflector and absolutely no glue on any of the treads so its completely user moddable. Sign me up!
problem is that their flashlights already have good leds/drivers/UI, so there is not much to gain, unlike with the Trustfire BLF editions.
Unless they do something like this :
An Archer 1A with XP-G2-3C mounted on copper mcpcb, with an extra turbo setting at 3A (when using an IMR 14500).
(The body has enough aluminium to handle the heat for a while. But I would doubt they would do the effort to redesign the driver for 3A, let go using copper mcpcb's)
