Ok, so it’s not exactly a budget light. but I figured I’d put a review since I was one of the early ones to get ahold of the TI4T
pros:
Titanium
higher lumens with same runtime as ti4
actual pen size
can be used in pen pockets, clipboards, organizers, etc
competitive in price with medical penlights
always starts in firefly mode
don’t have to cycle modes to shut off
Cons:
Gets warmer than ti4
heavier than ti4
would rather see have a 80 lumen mode rather than 30
can not utilize 10440 batteries
Specs:
Model: Ti4T
LED: Cree XP-L V6 LED with a lifespan of 20+ years of run time
Mode & Runtime (Tested with 2*Ni-MH/900mAh): Firefly(0.4 lumens, 137hours), Low (32 lumens, 12hours), High (300 lumens, 51minutes), Strobe (300 lumens, 90 minutes)
Material: Titanium
Operation
Unscrew the light head, insert the batteries with the negative terminal down into the battery tube and then screw the light head back on
Turn on /off
Single press the tail switch to turn the light on/off.
Change modes
When the light is on, twist to loosen then tighten the light head to change modes with the cycle of Firefly, Low, High, Firefly, Low, High, and Strobe.
When the light is on, half press the tail switch, Low, High, Firefly, Low, High, and Strobe.
When the light is on, quick double click (within 1 second) the tail switch to cycle through Firefly, Low, High, Firefly, Low, High, and Strobe.
If the second click is after 1 second but less than 10 seconds, the light will memorize the last mode. If it is after 10 seconds, the light will start from Firefly mode again.
Beam shot
Ti4T beam Vs Ti4 Beam
Ti4t Beam Vs Thrunite Archer 1C
Ti4t Beam Vs Thrunite T10
Tift Beam Vs Xtar Wk41
Conclusion:
as much as I love a budget light this is quite a little handy penlight. I really like that it easily fits in my cell phone case and and of my shirt pockets that have a pen loop. It’s very handy for work because I don’t have to worry about cycling through modes to turn it off, but it also has enough variety in lumens to make it worth my while to EDC. This would make a really class gift for any EMTs, doctors, nurses, dentist, or even LEOs that you know for xmas. It’s competitively priced with the Foursevens Preon 2 and the Welch Allen Doctor’s lights, yet it still has higher lumens and better run times.
One more beamshot for the road!
