Led Lenser P7.2
Hi my friends!
today i want to show you one of my first “real” LED flashlights: the Led Lenser P7.2
(i compared it with my Zeusray $7.99 light)
since i used it a lot it has some signs of wear - but due to its superb quality not much of them!
( it survived a 50m roll/jump down a cave
it has a pretty red circled tailswitch with a simple UI:
half press for turbo (320lm)
1st klick HIGH (250lm)
2nd klick LOW (40lm)
the size is very nice to operate the zoom with one hand - but geting to the switch is another story (like ALL tailswitch lights!)
you have to use the “tactical grip” or both hands (which is PITA if you want to use the turbo)
lets have a look into the bright end: (P7.2 on the right)
flood:
zoom:
the Zeusray uses a plastic aspheric lens (cheap²) while the P7.2 has a TIR Lens…
the TIR has less loss in brightness - but is more expensive.
a gif from the zooming…
beamshots taken 1m from the wall:
(P7.2 left on “my” high ;))
Led Lenser always “miss”adjusts the focus so it stays blurry - i tweaked it a bit to get a sharp image of the emitter (Cree XP-G2)
okay - lets open the beauty!
the battery carrier carries 4 AAA batteries:
one plus / two minus - batteries are in series
i love to disassemble things!
the spring loaded contact-”pins”
PCB Contact side
PCB Swich side
the switch - it only circles direct drive / left and right set of limiting resistors
veery “simple” for a “high end” light ![]()
there is NO! regulation at all! just direct drive with resistors in Series to the batteries to limit current which resuts in different brightness levels.
lets open the head:
removing the plastic ad carrier gives free vision of the LED on a custom copper PCB
that ARE flat contacted wires…
the pill:
the contact side of the pill:
the inner side of the contact PCB with one of the two current limiters
I DO NOT LIKE limits…
i hardly remember the numbers - but turbo went from 0,8 A to around 2A ![]()
